Color of power steering fluid is wrong?
Old Dec 25, 2013 | 01:29 PM
Greg Schroeder's Avatar
2007 S65
Hello,
I recently purchased a used 2007 S65 with 36,000 miles. The car makes a slight whining noise which seems to be from the power steering. It's the regular power steering type sound although the fluid level is correct. Upon investigation it seem to have red power steering fluid. From what I can gather the two correct products listed in the manual are green looking.
I don't believe there is air in the system, but it is possible. I've lifted the font of the car and turned lock to lock about 30 times while off and while running.
I'm not a pro, but any advice would be helpful. I enjoy working on cars and prefer to do things myself.
Old Dec 28, 2013 | 08:23 AM
2007 S65
If anyone would like to go look or knows the OEM color of power steering fluid in a W221 S65 that would be fantastic.
Old Dec 30, 2013 | 12:36 AM
GrepAwk's Avatar
'03 S55 (79K miles)
Pentosin CHF-11S has a light greenish color when new. Like Gatorade lime flavored.
Old Dec 30, 2013 | 02:01 AM
Primus63's Avatar
05 E55
^+1
Old Dec 30, 2013 | 06:07 PM
2007 S65
The noise was a pulley. I fixed it and it's silent now.
Old Dec 31, 2013 | 02:57 AM
benz_addict's Avatar
V12TT
Which pulley?
Old Dec 31, 2013 | 09:28 AM
2007 S65
pulley noise
Originally Posted by benz_addict
Which pulley?
The 5 pulley made the noise which sounded like the typical power steering low level when the engine gained a bit of RPM. It's literally silent and rock solid now. I also did the 4 pulley.
This is the car which I just purchased. It's in amazing condition.
Old Dec 31, 2013 | 08:11 PM
w4sim's Avatar
S55K AMG
Very nice car you have there, fantastic looking wheels.
Glad you got the problem sorted.
Old Jan 1, 2014 | 02:35 AM
V12TT
Looks great! Good thing you replaced that pulley. Mine fell off and left me stranded but it's a common problem. Do your self a favor and replace #8 as well!
Old Jan 1, 2014 | 04:24 PM
dtohio's Avatar
05,cl65;33ford3wc.
I would still check your p s fluid color, I think as others said its probably supposed to be green. If its the wrong fluid its a potential problem, flush and re do.
Old Jan 1, 2014 | 07:31 PM
2007 S65
The amazing thing is this car has been dealer maintained A, B, C, D with even extra services such as break flush and so on.
Old Jan 1, 2014 | 10:22 PM
w4sim's Avatar
S55K AMG
Take it back to dealers and get them to just confirm it.
It may have been dealer serviced, but someone else (local garage, or previous owner himself) might have changed the power steering fluid for some other reason.
Old Jan 2, 2014 | 10:42 AM
dtohio's Avatar
05,cl65;33ford3wc.
+1, A lot of mercedes fluids are not as compatible as the self serving aftermarket mfgs. suggest.
Old Jan 2, 2014 | 01:24 PM
2007 S65
I may be overly cautious, but just like to be safe. I did visit the dealer initially to investigate the history of the car. I inquired about the power steering color and they didn't seem to have any thoughts other than drop it off and we'll check it out. From the evidence of the records at the dealer it has been clearly maintained, so I chose to figure it out on my own
My current thought is the fluid is old and may have discolored slightly. The car is a 2007.
Here's an image of the fluid color in natural shaded light, no flash.
Old Jan 2, 2014 | 02:57 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
PS fluid will look clear but to me has a slight clear blue look to it in the can or on a rag.
I may have most those idlers in stock and machined out of bilet with ZZ rated bearings. I replaced all mine on my v8 years ago. I have 2.5" and 3" smooth or ribed billet idlers for most AMG engines.
A few examples.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 2, 2014 | 04:26 PM
w4sim's Avatar
S55K AMG
The dealer will only confirm what they dealers have done, they cannot confirm something that another garage may have done.
As has been said before, the Pentosin is a light shade of green, which turns to a very dark brown, near black colour when it gets old.
Unless theres something new for the W221 AMG cars then id say you have something different in there, not necessarily wrong, but different.
Get it checked for peace of mind if nothing else.
Old Jan 26, 2014 | 12:16 PM
Rfbarnes's Avatar
S63
I'm having that same problem with my s63 so it's the 5 pulley that makes the winding noises?
