V1 Hardwire Install Question
Planning on hardwiring my Valentine One radar but in order to do so I need to know which wire to tap into that I can draw power from.
So does anyone know which wire is the correct one to tap in the dome light/sunroof control thing?
02' S55 by the way
http://www.blendmount.com/mirrortap.html
2003 S55
K&Ns, 80mm TB, NPI headers, X-pipe / 3in pipes, Kleemann Cams & 168mm Pulley, ECU & TCU tune. 550cc injectors, Meziere WP136S SC pump. ASP Idler Pulleys, 84mm SC pulley, SC belt wrap, Fuel rail loop, LFR7AIX plugs, NPI heat exchanger, -10C mod, shift paddles, TeleAid removed.
Lowering links (1.5" front, 1" rear), 18x9.5+35 offset rims, clear side markers, KG Key retrofit, H/W Valentine1, BT phone, BT AUX, laser jammer
I've spent two years improving/restoring it on and off as time permitted, and now have a car that passes the STAR SDS quick test diagnostic every time with no errors, and everything works as it should. I went through those pesky repeatable -f- reports one at a time until they were all fixed. Having an engineering background forces me to work on something until is working 100%. I can't help it - LOL
There's lots out there, try this
http://www.radardetector.net/forums/...schematic.html
