2007 S65 rough idle after warm start
Old Nov 13, 2014 | 11:18 AM
japd99's Avatar
GL 550
Mercedes cannot figure this one out! I have a 2007 S65 with 65K miles. Just had service and spark plug change, hoping it would solve the issue. If I run the car to normal temperature and stop for 15-30 minutes, it has a problem when I start back up. Essentially, I start the car again and the RPM's go real low to where the car almost shuts off and is rough. It then spikes up to 2K RPM or so and evens out to normal afterwards. It's a little unnerving as sometimes if I am in a hurry and put the car in gear it can essentially "take off" if it is doing this.
Any thoughts or ideas on what this could be? I do not get a check engine light and supposedly no "codes" are detected at the Mercedes service department.
Thanks for your help!
Old Nov 13, 2014 | 12:49 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check for vacuum leaks
Old Nov 19, 2014 | 03:37 PM
japd99's Avatar
GL 550
I took my car in again to Mercedes and told them to check for vacuum leaks. They said that I could get a "check engine" light if that were the case. They did find that a couple of engine mounts need replacement and that may explain the "roughness" at idle. I'm not sure how this would cause the car to almost stall. They are also going to replace the rear engine seal due to an oil leak. What do you guys think? Does this sound legit?
Old Nov 19, 2014 | 04:39 PM
F1BHP's Avatar
sl600
Sound like dirty maf sensor. Get some maf cleaner and see if it fixes it.
Do yo have k/n filters?
Old Nov 19, 2014 | 05:55 PM
jettbird's Avatar
S65, bmw 745, escalade
Maybe coil bank issue. Does it code misfire? Mine did and it went away after replacement of left bank pack.
Old Nov 28, 2014 | 04:50 PM
japd99's Avatar
GL 550
Smile Update
A week and $4500 later (covered by my aftermarket warranty ) I got my S65 back. The car is running like new again. The engine and tranny mounts were all replaced. It is smooth and so ridiculously fast! I am extremely pleased. Interestingly, yesterday my friend let me borrow his Ferrari FF. Yes, the Ferrari is a fast ride and I loved it but my MB is so much smoother and seems so much torquier! Yes, I know...Different cars.
Hopefully good to go for a long time now. One piece of advice- Get an aftermarket warranty on these cars after the original runs out. They are super expensive to maintain, especially if you're picky like me and want to keep them perfect. My '07 has 65K on the odometer and looks like new. The best thing about these cars as opposed to a Ferrari is that I can drive it regularly and not feel as guilty putting miles on the car.
Only other thing I want is a thicker steering wheel. The wood looks nice but feels so thin compared to newer cars, it almost makes the car feel wimpy. Any ideas of where I can pick up a nice steering wheel for this thing?
Old Nov 28, 2014 | 05:26 PM
F1BHP's Avatar
sl600
The mounts would not cause fluctuating RPM's. Sounds very strange unless they did other work while they were there.
Old Nov 28, 2014 | 08:21 PM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
Most company's don't warranty v12s ! What company is your warranty through japd99?
Old Nov 28, 2014 | 09:52 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Fidelity will, they covered my car including that crazy engine mount job and ABC issues like the pump/strut/valve block. I got a good deal for 4 years / 50k miles full plat. for about 4 grand, but my mileage was really low.
Old Nov 28, 2014 | 11:29 PM
Engine mounts do cause rough idle on these V12, if it was minor fluctuating in the RPMs then mounts could have been the issue but if it was really jumping more like coils or a bad crank sensor or god knows what else. But after I did engine mounts last summer my car road like a new care
Old Dec 12, 2017 | 09:22 PM
JohnLane's Avatar
222 S-65
I have a 2008 S-65 with 62,000 on it.
Smells as as similar issue described above. Perfect drivability from stone cold. Park fully warmed up for 15 minutes to an hour... 'Hot soak restart' makes for very rough idle... Has done this many times since I purchased the car. Today it lit a check engine light. Misfires for virtually every cylinder+ multiple misfire codes. Coils, plugs are fresh. Runs perfectly except for the hot soak restart.
MB tech speaks of paint they got to apply to ring gear or some such when they were close to new.
Thoughts?
This is is not engine mounts. It misfires.
Thanks.
Old Jan 11, 2018 | 03:26 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Thoughts?
Thanks.
Is your ignition transformer new also?
Old Jan 15, 2018 | 08:40 PM
JohnLane's Avatar
222 S-65
yes. Same age as both coil packs. All look to have been replaced immediately prior to my purchasing the car... Cam cover gaskets got done at the same time. May have been the straw that broke the previous owner's back.
I will put a pressure gauge on the rail and see what that does after a hot soak.
Old Jan 15, 2018 | 08:53 PM
ItalianJoe1's Avatar
2003 CL 600
It's the fuel pressure. There's a bulletin on the older cars, I had the exact same issue on my CL, had to replace the pump/regulator/filter. Got way better.
The root of the problem is ethanol in the fuel. It boils at a lower temperature than gasoline, so you get a vaporlock issue when it heat soaks and can't get liquid gas into the engine. It wasn't present in pump gas 10 years ago. They've raised the base fuel pressure so it doesn't act up as much anymore to compensate.
https://mbworld.org/forums/s-class-w...ngine-out.html
Last post on the first page, the bulletin is linked.
Old Jul 5, 2018 | 04:08 PM
JohnLane's Avatar
222 S-65
FYI guys.... Since the change to 'summer blend' gasoline.... Zero issues with hot starts.
