Emergency help Please!!
Old May 7, 2015 | 08:11 PM
Neo0019's Avatar
2002 430S
I went to do groceries well after an hour walking around the store we put everything in the trunk of the car (it open with the key fob) I put everything inside turn the ac on and go we stop on the way home for ice cream and now the key fob won't lock or unlock the car or open the trunk, it won't even unlock the car from the inside or move the head rest at all it won't open the trunk from the switch on the driver side door nothing will work I check the fuses on the rear they're fine I check underneath the rear seats for the red cable, to see if it was broken. Or something but is fine. I have groceries in the trunk and is supposed to be 85 tomorrow please any help will be appreciated..... Sorry for my English
Old May 7, 2015 | 08:42 PM
DRTYLNDY's Avatar
On your key fob there is a metal key where the key chain is. Remove it and in the back under the lip of the trunk is a very small key hole and you can manually open the trunk.
Good luck.
Old May 7, 2015 | 08:49 PM
Neo0019's Avatar
2002 430S
There's nothing there for me to put the key in. And I should also said. When I lock the car the lights flash. And when I open the door with out pressing the unlock button the alarm goes off
Old May 8, 2015 | 02:49 PM
Neo0019's Avatar
2002 430S
Anybody please help!!!!!
Old May 8, 2015 | 03:21 PM
Hank Kingsley's Avatar
2005 S55 AMG
Will the little key in the FOB let you in the car?
If so will the trunk open from inside the car?
I had the alarm horn go bad in my 2nd week of ownership and the car would lock itself and lights would flash and a siren would go off.
But I was always able to use the fob.
Old May 8, 2015 | 03:52 PM
Neo0019's Avatar
2002 430S
The little thing where the key go. Is missing in my car I bought it like that I guess. But when I press the lock button it flashes the light but that's it the lock key that inside the car won't lock or unlock the car. So does the head restraints button won't put the rear head restraints down
Old May 8, 2015 | 03:55 PM
2005 S55 AMG
But the FOB still has the metal key in it?
That should allow you to unlock the driver's door and try opening the trunk from inside the car?
Old May 8, 2015 | 03:59 PM
Neo0019's Avatar
2002 430S
Oh I understand I'll try that after work. Do you by any chance know how I could reset the PSE pump
Old May 8, 2015 | 04:00 PM
2005 S55 AMG
Way beyond my expertise.
Hope I helped.
Old May 8, 2015 | 04:03 PM
Neo0019's Avatar
2002 430S
You did. Thanks!!! I'll try locking the car later on today
