S55 2004 - Battery Dead - Can't open trunk!
Old Jan 8, 2016 | 01:07 PM
G.Factor's Avatar
S320 '96, W123 '78, S55 AMG '04, S350 '05
Exclamation S55 2004 - Battery Dead - Can't open trunk!
I know this sounds stupid, but I parked my car in the garage too close to the wall, the battery is dead so I cannot power it, the trunk wont open due to the car being too close to the wall.
is there anyway I can find a + terminal under the hood? ( I can't locate it)
If i can put the car on neutral and just push it 1cm fwd. it will solve the problem.
But of course the shifter won't shift.
any ideas?
Thanks!
Old Jan 10, 2016 | 01:57 PM
Dr Matt's Avatar
05 CL65
I'm pretty sure you should have a power relay under the passenger front carpet just like my CL does. Pull back the carpet from the firewall and you should see an aluminum plate held there by a few nuts. Remove that plate and under it you will see a relay that is the termination of you main power cable coming from the battery. You can jump or charge the car right there.
Old Jan 18, 2016 | 05:00 PM
G.Factor's Avatar
Couldn't find the relay under the carpet.
Also I've purchased battery tinder that goes into the cigarette light socket, I wasn't going to start the engine, only wanted to disengage the shifter to N so I can push the car 2 inches forward. but it gave no power at all.
Old Jan 18, 2016 | 07:25 PM
evansw220's Avatar
'01 S500 AMG Sport, ABC,Distronic,Rear Side Shades // '10 E350 P2, Pano, BLK/ALM,4MATIC Sport
One other option there is too remove the driver side front 'SAM' under the hood by the brake booster.. Unclip the control unit and pull up straight you'll see the red power cable..remove it and jump it with a booster pack at the cable and ground it somewhere on the engine block or any ground insight.. That will allow you to power the electronics to open the trunk.. Return everything after get the trunk unlatched...
Old Jan 20, 2016 | 12:45 AM
hvacdude's Avatar
2006 CLS55AMG & 2005 S55AMG
Get a set of "car dollies" {"Google it if you don't know what they are}, jack up the car , put a dollie under each wheel, slide the car away from the wall, open the trunk and jump start, charge, or replace the battery.S55 2004 - Battery Dead - Can't open trunk!-car-dollies.jpg
Old Jan 20, 2016 | 02:04 AM
wahshk's Avatar
W221 S65 AMG, Porsche Panamera Turbo S
can you post a picture of the engine bay close to the passenger side. You might have the plus terminal there. I don't have your model but a picture may help.
Old Jan 22, 2016 | 11:04 AM
hegar817's Avatar
2003 s55
Cant you open it manually by using the key clipped inside your key fob?
Old Jan 22, 2016 | 06:17 PM
evansw220's Avatar
He should be able too but if the latch that pulls up the lock is not properly making contact it's a no go...
Old Jan 23, 2016 | 05:00 PM
G.Factor's Avatar
Old Jan 23, 2016 | 05:08 PM
G.Factor's Avatar
Originally Posted by hvacdude
Get a set of "car dollies" {"Google it if you don't know what they are}, jack up the car , put a dollie under each wheel, slide the car away from the wall, open the trunk and jump start, charge, or replace the battery.Attachment 323588
The dollies seem like a smart idea, I think it will be my last resort.
Thank you all for the help
Old Jan 23, 2016 | 06:45 PM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Can you not get in the car and put it in neutral and try pushing it a bit?
Old Jan 23, 2016 | 11:07 PM
wahshk's Avatar
A picture towards the upper passenger side would be better. Somethings similar to this could be hiding under a cover which looks like this.
Old Jan 26, 2016 | 02:01 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
Battery tenders or trickle chargers take hours to get a dead battery able to start the car. For faster charging through the cigarette lighter, you could get a quick jumper like one of these: https://jet.com/product/detail/50748...KJ4aAinQ8P8HAQ
Old Feb 2, 2016 | 05:09 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Before you buy such a device...
You might want to verify whether your cigarette lighter socket(s) stay alive on the vehicle when the key is withdrawn.
As far as I recall, the center console (dashboard) cig lighter is on a relay that opens up (disconnects) when you turn off the car.
I'm not sure about the storage console, or the ones in the rear doors ash trays.
Plus, there is no way in heck that you can put over 30+ Amps through those wires to jump a vehicle with a truly dead battery. Even if there is no relay, you will fry the fuse.
You might as well throw a match into the back seat and see if it lights first. It is odd that the gadget-makers advertise that as a feature.
