M113k Manual gearbox, standalone build thread.
currently swapping a 6 speed from a Crossfire into it.
so we did a thing to a e500 to make it more fun to drive
Ok, so for those playing at home there's two different crank bolt patterns. There was a changeover somewhere around 2005 for the M112 V6. One is a more or less concentric equal spaced 8 bolt pattern and one has 4 bolt holes spaced differently. I'm not sure which one is early and which one is late model,
I have also worked out where to get solid flywheels for the M112/M113 and get rid of the dual mass crap. Surprisingly cheap too.
You dont have to use all 16 plugs - I'm only using 8 on my M113 standalone. I believe you can use the stock Mercedes coils as they are just two 2-wire coils using the same 12V signal but separate grounds. My next step is to use stock coils but only wire up one plug to fire.
