S65 timing chain information needed.
As far as a swap into a lighter car, if your looking for performance there are way better choices than these engines. Maybe for a nice sound or a small hydro, or airplane??? You know that V12 sound.
So hopefully doing all this work gets you more than 40,000 more miles, you said the other one crapped at 70,000.
As for better engines for a swap, I know of no other engine that makes as much power, as smoothly and effortlessly as the M275. The only downfall is the ignition coil design and they're just not as much of a problem as people make them out to be. Seems like an excellent candidate for a swap to me. But that's just my .02.
I'm failing to see how even Elroy could manage to screw it up so long as he doesn't just shove a prybar in the middle of it and reef on it.
Just a little patience working one end + the middle.... The other end + the middle.... I've sure got to wrestle with worse!
Speaking of coil packs.... I've heard many and varied horror stories of coil packs breaking while being removed.
My car that started life with the dirty dozen will get the MB six liter for now. Perhaps in the future it gets upgraded with cylinder head work, exhaust that isn't so ugly that feeds a bigger pair of turbos and doubled up charge cooling. Cuz 740lb/ft is obviously not enough!
I'm just saying there are better engine swap choices. Open deck engines are not good performance engines.
And sorry to say it is just a cheap to build design, it is a typical trade off. That is why I consider newer mercedes engines very expensive throw away items.
A sample of open deck. https://www.e90post.com/forums/showthread.php?t=196558
On a serious note, any updates?
Seems the timing chain issue with a dozen bent exhaust is secondary to the first failure.
Having pulled the timing cover it is clear to see what happened. The front main bearing spun and spit a bearing shell forward into the chain drive.
Anyone heard of or seen such issues in a 275? Or did I win the Powerball and Mega-Millions on the same day?
If I can figure out how to post pics on the BB I have several.
Looks like the EV12 project will need a different donor.
do you know this Videos-Series?
https://www.youtube.com/results?sear...engine+rebuild
I watched every part and it is very interesting. If you have some questions regarding Timing Chain, Tasos sure can help you if he has time.
I would still recommend to use WIS.
I guess another possibility is that the oil supply to that bearing could have been clogged which limited oil supply to the bearing.
Any pics of the broken chain guide?
