S55 AMG HeadUnit Upgrade
Old Sep 5, 2018 | 11:15 PM
CrypticEdge's Avatar
2005 S55 AMG
Question S55 AMG HeadUnit Upgrade
Hello, my name is Ryan and I recently got my license and got an s55 AMG 2005 for my first car. I love the car, its power, its comfort, everything, but the command is hard to deal with. For my dad, who primarily used CD's it was not an issue, however, I want to listen to music via my phone, and this year s55 does not have an aux cord or Bluetooth (obviously) so I was looking into swapping the head unit for an android clone. Are there any good models that are up to date and don't cost an "arm and a leg"? Also, before anyone recommends this, I tried getting a Bluetooth FM transmitter, and while it does work, it does not sound very good and has high amounts of static during use. Thanks for the help and any advice is appreciated!
Old Sep 5, 2018 | 11:16 PM
ItalianJoe1's Avatar
2003 CL 600
Quick check on Ebay shows them all over in the $400-500 range. I'd start there.
Old Sep 5, 2018 | 11:19 PM
2005 S55 AMG
Yep, that's where I've been looking. I'm not sure what I will need to accompany those models to make it work "like stock" with the steering wheel and the bose system since there are no clear customer reviews or tutorials on most.
Old Sep 6, 2018 | 03:31 AM
mfl's Avatar
mfl
500SE S600 500SL S55 AMG Kompressor SL320
Also getting the time set in the instrument cluster could be interesting.
External inputs are possible via the TV Tuner (if installed). They will show up as AUX1/2.
Old Sep 6, 2018 | 11:38 AM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
You don't want those. They are trash. Look at a Dension unit for your stock player first, if you must have BT streaming music. IIRC, you can couple it with a storage drive full of MP3s. I did one of those clone units in my E46M -- complete trash, but better than the broken unit there. COMAND is WAY more than a radio, so you don't want something trashy covering that much ground in your S55. They will never work "like stock". You'll be sorry.
Amazon Amazon
maw
Old Sep 6, 2018 | 06:36 PM
2005 S55 AMG
https://www.amazon.com/Dension-500-G.../dp/B008XOMGNO
maw
So if I'm correct the Dension unit allows me to use AUX and I would be able to run that to the front of my car I assume, but can you explain the Bluetooth route you were talking about? that would interest me more than Aux. And keeping the Command stock is my preferred method anyway so I like these ideas better! Thanks
Old Sep 6, 2018 | 10:08 PM
maw1124's Avatar
See here... https://www.dension.com/automotive/p...ns/gateway-500
You may need to call them. I don’t understand how the Gateway 500 is compatible but their BT solutions aren’t. Could just be a wack web site compatibility function. From what I understand, their module is the Bluetooth connection, that lets you control iDevices and USB music sources as well. But I haven’t tried it. I just burn MP3 music to DVDs and let that be that. At like 600 songs per, I’m not in the car long enough to need any more. But I’m not a teenager either. My kids are, and they ask about BT, which is why I’ve even thought of it. They take over the BT systems in the other cars, much to my enjoyment. If BT phone is important to you, I’d go factory, then use Dension for music only. So you now have 2 music solutions (Dension and DVD MP3), and factory everything else, which I think is the best of all worlds.
GL
maw
Old Nov 4, 2018 | 01:50 AM
2005 S55 AMG
How would I check if I have the TV Tuner and how would I get my phone to connect via aux or bluetooth to it? Sorry for the the late reply. (Very Late lmao)
Old Nov 7, 2018 | 02:51 AM
Daniel Yuen's Avatar
'05 S55, '05 C55, '13 E63 Estate
Hi Ryan,
When I first got this w220, I had the same irk to have an aux cable installed for my kids YouTube or a meditation stream off my phone. I had the NAV-TV MOST model installed replacing the multi CD changer, which I don’t regret. One thing after two years of ownership is that the aux cables can get loose and you will lose signal to the right speaker.
if you are like me I would first double check your ABC system to see if it is “happy” and then go about calling NavTV before making your purchase. I forget the guys name but he was super helpful. The aux only is $299 I believe.
Feed a female aux through the bottom of the head unit
best, daniel
