Newbie with an S55--Quarter mile times and Questions
Ok so first question....the front sits low, and makes some sqeaking noises, so I'm thinking maybe bad and/or the wrong struts? I think the guy got the kit used and it's for a S550 or model other than an S55.
I'm a hot rodder (I have a 11 second diesel truck and an 8 second Nova) so I also had to take it to the track, but didn't get the best results and couldn't hook at all. Ran a 13.08 at 107.5 mph with a 2.10 60 ft and 108.5 mph on another pass. Is that about in line with what people are seeing stock, and tractionless? Shifting seemed good although definitely designed for full throttle comfort rather than E.T.....it was a street car night and no VHT was put down (and DA was about 2,000 ft) so on a prepped track I'm sure it would run 12s (which is what I was hoping for).
Ok so next issue, who should I look for tune-wise to run on CA's 91 octane? How about a blower pulley and TCM tuning? Yea or nay? Finally, I switched to larger tires to fill out the rear fender more, and it seems the cruise stopped working now because the fronts and rears are different past the allowable limits (thanks forum!) So, any way around this? Or try and wheel and deal with the tire shop to get a matching set.
Anyways, thanks for reading or skimming (those who did) any advice is appreciated! Also have a couple sets of wheels and tires and ABC struts and pump if anyone is interested. Guy was working on converting it back before he sold it.
Remember.... The most expensive Mercedes ever encountered will have been a low price high miles deal!
Car actually has 2.65 gear ratio.....
I would go with pulley, bwk, ecu tcu tune
Plenty of dealers, pick your poison
these cars pull timing early so anything to keep the iat down, trunk tank or meth.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
