2010 s550 w221 programming issue
Old Jul 30, 2019 | 03:54 AM
naderk08's Avatar
2010 Mercedes s550
Hello I’m new here, a mobile key guy came to make me an extra key and messed up the coding on the car, now the lights and signals don’t work a whole bunch of lights are on the dash and the gauges don’t work, I brought a friend of a friend that used to work for Mercedes come out and he told me that it won’t let him enter the modules and it shows it’s in theft mode (but the car runs and drives), any help would be appreciated before I spend an arm and a leg at the dealership thank you all in advance
Old Jul 30, 2019 | 06:43 AM
speedlimit's Avatar
Administrator Emeritus
Hi and welcome to MBworld!
Good luck troubleshooting your car! Moving to W221, thanks.
Bob
Old Jul 31, 2019 | 04:29 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
That does not make sense to me. Was the EIS removed when the friend made the key? If the Immobilizer was tripped, it would or start. And you could still communicate with the control units.
Old Jul 31, 2019 | 04:42 AM
naderk08's Avatar
2010 Mercedes s550
No this was done all obd I was watching him, he said he had an error and that’s when everything went haywire
Old Jul 31, 2019 | 04:49 AM
Polar Bear's Avatar
Did he tap into other wiring in the vehicle or disconnect the ESL (electronic steering lock)? I assume an IR key was used to extract the EIS password?
Old Jul 31, 2019 | 12:54 PM
naderk08's Avatar
2010 Mercedes s550
Not sure but I was told the Sam coding is bad or the central gateway is bad I just don’t know how to go about it
Old Aug 2, 2019 | 11:27 AM
Polar Bear's Avatar
All you would need to do is simply have them
both SCN coded and it will put them in their factory state.
Old Aug 2, 2019 | 11:49 AM
naderk08's Avatar
2010 Mercedes s550
Thank you, I hope your right about the simple part, is the dealership the only place that can do it?
Old Aug 3, 2019 | 03:48 AM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
I can but if you're far, then dealership, they might want to replace stuff just tell them you need a SCN or module update nothing more....
Old Aug 3, 2019 | 11:19 AM
naderk08's Avatar
2010 Mercedes s550
Ok thank you yes I think your in the east coast I’m in California
