S65 W221 Engine Rebuild
I bought s65 2008 w221 with a problem. It consumed extra oil, by extra i mean 1.5 liters of oil every 500km. I have disassembled the engine. Cylinders are in good shape. They do not have marks or scratches. I am going to check if it is ellipsed or anything. Piston rings are deformed and must be changed. Piston rings does not come without pistons itself. I have checked with MB centre in my hometown. What can you recommend for me to do? I do not want to purchase very expensive pistons. I just want to change the rings.
See below links to see what I am talking about.
The set you found on ebay can be had for A LOT less https://www.weddingsp.com/index.php?...ucts_id=779333
Good luck with it.
So cylinders have ellipsed (means it has bumps from previous piston rings that are no visible by eye but can be determined by and deformed, i need to put cast iron sleeves. But this Rings are made for aluminium cylinders. What Can i do? is it ok to use them with cast iron steel? If not, what is the solution?
found them on car-part.com
if you look on there at different years you can find them closer, for less money.
Wait, being that you put KMs, and spelling some words like center centre, I am guessing you might be in the Republic of Georgia, not the State of Georgia, in the US
guess the Car-part.com site might not work for you
The engine i disassembled has 25k miles on it and its in this condition. Rebuilding costs me maximum 3K USD in Georgia. So its much cheaper and after doing it i will know exactly what is under the hood. I just need to get these piston rings. it has to be compatible with cast iron sleeves that's it. If i buy one of these motors it will cost me much more and maybe this engine will need maintenance too.
Contact info
NPR of Europe GmbH
Siemensstr. 56D-70825 Korntal-Münchingen
Tel.: +49 (0)7150 9163-0
Fax: +49 (0)7150 9163-100
info@npr-europe.com
Contact info
NPR of Europe GmbH
info@npr-europe.com
Good luck with it.
They have done well for me in the past...
I have some new chain guides and other gaskets ect I'll make you a deal on for your M275. Purchased them when I was expecting to be repairing my engine when it spat a main bearing shell into the chains. That engine got replaced with a newer low miles used engine.
