S55 no start stuck in park. Help!
Undervoltage codes.... 'The battery store' rather famously finds MB batteries to be good that are not.
Keyless GO? If so, pop the button out of the EIS and insert the key. Does the car wake up when key is inserted? Does the key turn? If the key turns... Does she start?
My experience of 220 cars doing as you describe..... Keys fail 10 to one dead EIS. Keep in mind that your car is well and truly old enough to have most anything to be pissed about electronically. EIS and keys require paperwork at MB. Bring ownership papers with you should any of that be needed.
First up... Once you KNOW the battery is healthy... Get after fuses. Use a test light with a real incandescent bulb as it draws just a bit of amperage, where the 'Disney LED lektronik logic probe' will somehow manage to light up even with bad connections that will pass zero amps to operate a circuit.
You mention certain features did not appear in the cluster when you try to start it. Smells of fuse or SAM (Signal acquisition module) issue. Happens.
Firing the parts cannon at the car will burn too many dollars to not get to the prize. You mention replacing a starter.... Jump battery voltage to the small wire that tells the starter to work. It will crank.
Should this be beyond what you can chase.... Better to get it to a knowledgeable, reputable independent or MB dealership and take your lumps.
I checked fuses all good. I checked the 2 larger red power wires that connects to the EIS and they had no power. So, after much research, traced the problem to the pre fuses X4/10 (located underneath the passenger footwell carpet. I check the fuses and I had a blown 60amp fuse (which is for the EIS). Replaced the fuse with a new 60 amp fuse and the fuse blew again, when I tried to start the car. Do you know how I can trace where those wires go? I know I need to check the resistance to ground on that circuit but I am not sure where to start. Thanks for all your help. Shelly
Which electrical circuits were acting screwy in the days/weeks before your car decided to have a Time-Out? Look to those first.
Git to it! You can do this.
With they replaced 60A fuse, were you able to turn the car to ACC on, and move the gear selector with the lit up dash and all that fun stuff? That may help narrow the issue. If you can do all that but blow the fuse upon crank, we’ll then I would gamble a new CPS (crank position sensor, known problem), or perhaps even a starter. It might be worth another 60A fuse. This hunt and peck is cheaper than the dealer, for sure, and probably more effective.
GL
maw
OP: Do recheck that the lead to the starter that tells the starter to operate is not installed such that it can be making contact with a ground.
FWIW your car is old enough to be having issues in the engine wiring harness. God be with you should that be the case.
Progress report?
If ur blowing out a 60A fuse then u got a big short I would check around the fuse maybe the circuit is touching the bare metal or something could u include pics but I think that u definitely have a problem very close to that area because that is a big short so it should hopefully be easy to locate. oh and did u get any wiring diagramsthose help out alot.
Black connector 3 wires ( middle and right wires both have power) Left wire purple and black no power. It maybe be a ground wire. No sure.
Heard something click ( not sure if it was the solenoid or not ) with the ding ding ding going on. LOL
I was wondering if my car could be in some sort of security lock down. 😳
Sooooo you can get it to crank with the tester..... Turn the key to the run position and ask that starter to operate with the tester. Does she light up?
Yup. Security has locked you out. you tried too many times! Much like the computer when you start trying all the passwords cuz you forgot. Try again in a month! LOL. More seriously....
I don't know if the 'Alarm/security' system MB gave your 220 car just interrupts the starter circuit or if it also keeps fuel/engine management from happening. Usually such systems go the easy route and keep the starter from working. That said.... The 'siren' in your car has it's own battery that is well overdue to have died. Those usually fail such that the siren screams incessantly.... and the starter won't work cuz it is convinced you are busy stealing the car.
