Let's start another ABC thread!
Old Feb 25, 2024 | 08:44 PM
S_Holford's Avatar
2003 S55 AMG, 2005 C320 Coupe, 2020 Jeep Gladiator Mojave
I haven't driven the car a lot lately due to working crazy hours. Today I made a 140 mile round trip, pull into the driveway and my tandem pump sounds like rattling ball bearings. Fluid level is good, no leaks, no dash lights, just noise today and the occasional steering feeling stiff (which I also believe to be an indication of something about to take a *****). Am I experiencing imminent tandem pump failure here? Fluid is still clean as well. According to the car's maintenance history the pump was replaced around 70k miles, has 145k now.
I've seen the rebuild kits but this doesn't sound like a failure of soft parts. I suppose on a good note the car made it home without fragging anything and resulting in a tow.
Old Feb 26, 2024 | 10:53 AM
CICBarkeep's Avatar
2005 S55 AMG, 2001 SL500
I almost hate to ask, but did you check the power steering reservoir? Recently changed the filters in both reservoirs on mine and while the ABC level was spot on, the p.s. fluid barely covered the tip of the dipstick. Just a thought.
Old Feb 26, 2024 | 02:10 PM
S_Holford's Avatar
Yep, it was actually the first thing I checked. I’m wondering if the rattling I’m hearing is broken springs inside the pump. I looked at a few rebuild videos on the pump and I haven’t seen anyone mention if and where they can get the hard parts, such as springs. One guy mentioned a “close match” from McMaster-Carr but I don’t think I’m gambling on “close” or trimming coils. This is one of those jobs I don’t feel like tearing into twice out of incompetence on my end.
Old Feb 26, 2024 | 02:39 PM
CICBarkeep's Avatar
Way beyond my capabilities so I sure don't blame you there. You might private message Philly or Maw and see if they have any suggestions.
Old Feb 26, 2024 | 11:04 PM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
If no one chimes in, and in the meantime, maybe reach out to eBay seller autohubshop, who literally has dozens of tandem pumps for sale, and try to quiz him about how they go bad. If your filters are clear and your fluid is at the right spec, who knows? I certainly don't. But people here and those selling the part would be good people to ask.
maw
Old Feb 28, 2024 | 09:55 AM
JohnLane's Avatar
222 S-65
Not a one mention of the most common failure!
The little Nitrogen bomb that threads into the pump. Do this first unless the fluid has glitter in it which says the pump has ground itself to bits.
Old Feb 28, 2024 | 12:08 PM
CICBarkeep's Avatar
Did some reading and a number of people mentioned symptoms like yours and it turned out to be the pulsation damper. Passenger side front wheel well on the S55 AMG.
Old Feb 28, 2024 | 12:23 PM
maw1124's Avatar
I figured he'd done all of that already. Folks EVERY question about suspension or power steering on these cars starts with fluid, filters and accumulators. Every. The inquiry may not end there but it must start there.
maw
Old Feb 28, 2024 | 01:52 PM
S_Holford's Avatar
The accumulators, fluids and flush (ABC, brakes & trans) were the first order of business when I bought it. I appreciate the responses though. I'll have to dig into it when I have time. Speaking of time, if the tandem pump is taking a dump I'll probably just replace it and be done with it. I did look up autohubshop on ebay and it appears as though he only had used ones for sale, but I'll check again since the wife tells me I'm blind! I'll also look around to see if I can find a reputable re-man with some kind of warranty.
Old Feb 28, 2024 | 02:21 PM
maw1124's Avatar
Yes, autohubshop is used... but everything I've ever gotten from them was in very good condition.
Pro Tip: typically on their listings, at least one of the pics will show the VIN of the car and sometimes the description will disclose the mileage. So you can get choosy from there. I wouldn't hesitate to put a low mile OEM pump in one of these. I might regret it, but I wouldn't hesitate. These parts are VERY robust, and if the mileage is low enough, it's very tough to destroy them.
maw
EDIT... + they have a 90 day warranty... maybe someone here knows of a hydraulic rebuilder or you have a hydraulic shop in your town that can rebuild them.
EDIT2 ... rebuilt pumps on Amazon
Amazon Amazon
Old Mar 10, 2024 | 08:51 PM
S_Holford's Avatar
maw
EDIT2 ... rebuilt pumps on Amazon https://www.amazon.com/Steering-Tand.../dp/B0CJP4ST3H
I guess I'll be the guinea pig for the Amazon pump. I received it a couple days ago, packaged well, doused in oil inside the bag. Ebay has the same one except they ask for a core charge, Amazon does not. Initial thoughts....the gunmetal paint doesn't appear very durable and I'm not crazy about the paint inside the electrical connector, but we shall see. I'll give it a fair shake and hope I won't be doing this job twice.
Old Mar 10, 2024 | 11:01 PM
maw1124's Avatar
John were you aware of any changes to the pump between 2003 and the end of the model year run?
If there were any upgrades or superseded parts, maybe the rebuilds have them already.
maw
Old Mar 11, 2024 | 06:27 AM
CICBarkeep's Avatar
Good Luck with the install.
Old Mar 11, 2024 | 08:26 AM
S_Holford's Avatar
Thanks, can't exactly say I'm looking forward to it! We'll see how I feel Friday.
Old Mar 11, 2024 | 08:58 AM
CICBarkeep's Avatar
Keep us posted!
Old Mar 11, 2024 | 11:09 PM
JohnLane's Avatar
222 S-65
maw
I have not wrestled with the tandem pump in a 220 car. Just my 221 S65. That consisted of replacing the nitrogen bomb and moving the pump from the engine that spat a bearing shell into the chains to the replacement. I have not yet had an ABC pump fail on me (Knock on wood!) In 130,000 miles of driving ABC equipped cars.
Old Mar 12, 2024 | 04:15 PM
maw1124's Avatar
When you get it out please let us know if it’s original.
GL
maw
Old Mar 13, 2024 | 11:11 AM
S_Holford's Avatar
Per the maintenance history it's already been replaced once at 70K. I'll be sure to get some pics though.
Old Mar 13, 2024 | 11:15 AM
maw1124's Avatar
Understood. Replaced with what and by whom is the question. OEM by dealer or something else by owner in the garage?
maw
Old Mar 13, 2024 | 11:32 AM
CICBarkeep's Avatar
Looking at the VMI on mine and it says the pump was replaced at 78.799 miles. Part number A0034662401.
Old Mar 13, 2024 | 11:38 AM
S_Holford's Avatar
The 70k replacement was performed at a dealership. Whether it's the same one is yet to be seen. The support bracket to the pump was missing and all the banjo fittings were leaking when I bought the car so someone has definitely had their hands in there at some point. FWIW, it was owned by a family that ran a BMW repair shop. If this car is any indication of how they run their business, I feel sorry for anyone that's taken their car there! They clearly didn't care about this car.
Old Mar 13, 2024 | 11:40 AM
maw1124's Avatar
Geez...
@CICBarkeep yours appears to be an OEM replacement. The owner of that car before G just took it back to the dealer for nearly everything as I recall.
maw
Old Mar 13, 2024 | 11:52 AM
CICBarkeep's Avatar
Lots of entries, that's for sure.
Old Mar 16, 2024 | 08:23 PM
S_Holford's Avatar
Finally got around to pulling the pump today and it was relatively painless until I got to the PO’s shoddy work again.
I previously added the missing rear bracket and bolt shortly after I got the car. Today I found out It was the only bolt that was tight.
The two upper bolts were loose and the wrong bolts. They had uncompressed lock washers too…kind of defeats the purpose of them! One of them was also previously broken off in what I believe is the timing cover, but they said the hell with it and loosely tried to thread it.
So now, I have to figure out if it's worth the trouble of extracting the broken bolt.
Old Mar 17, 2024 | 02:15 PM
S_Holford's Avatar
A little progress. I refuse to let a car beat me
Broken bolt extracted
FWIW, save yourself a headache when drilling out bolts (or hardened steel) and use cobalt bits. For anyone that doesn’t have much experience with this, cutting oil and low drill speed prevents burning up your bits.
