Gearbox trouble, big or small..?
First of all, I'm a bit surprised to see that here is no thread alternative for S600..?
(My car is a CL600, but I wanted to increase my chances of response by writing here also, since the same gearbox sits in the S600. Probably even in 55AMG & 65AMG, only with quicker TCU.)
Anyway,
Last week I bought a CL600 from 2008 in Germany and drove it home (to Sweden).
On my way home I spent a night at a hotel, about half way home.
The next morning the car was of course cold, and made TERRIBLE gear changes to second & third gear!!!
The guy had me fooled of course, by showing me the car all warmed up!
My mechanic says that the car does rev quite high before it moves, even when warmed up (like a manual car with clutch all worned out).
So I now have three choices;
- Flush the gearbox for about 500 dollars (small problem).
or
- Buy a used gearbox at eBay, för about 1.000 dollars.
or
- Renovate my gearbox for about 2.000 dollars (big problem).
What would you guys choose..?
And do you have any experience on this matter perhaps?
Oh, and btw the purchase was made from a private person, so no use in even call him about this. It's an obvious con.
Thankful for your thoughts!
Best regards
Roger
There are a ton of Dodge/Mercedes transmissions available on Ebay, but I am not sure they are compatible with the specific version in the V12 cars, and finding a good V12 Trasmission is going to be difficult.
I have a tool that cross references used auto parts in the American market. You put in what you need (2008 W221 S600 transmission) and it gives you all the parts that will fit. What it came back with was only S600 and CL600 transmissions.
Anyway,
or
or
Best regards
Roger
First thing I would do is check the fluid level, which is sort of your first option. I’d change the filter while at it, and inspect the trans plug O-ring for leaks. Leaky fluid can wick up the harness and into the TCU, destroying it.
Doing this will tell you whether the other two options are of any value to you at all.
Conductor plates are also known issues on these transmissions, often from leaky fluid through the harness but not always. Best case, it’s a simple fluid and filter. Worst case, well that’s a lot worse, so start there and report back.
Cheers and GL,
maw
Start there first. If that fixes the issue, do a complete trans service. Filter, conductor plate, 13 pin connector, etc. FCP Sells the kit. As mentioned above these transmission are pretty robust, it wouldn't suprise me to be low on fluid due to a leak somewhere.
GL
- Joe
GL
- Joe
OP, you were on the right track when you asked the question. Stay with that at least through Option One. If it gets more complicated than that there are plenty of us here to advise you beyond "diagnose".
maw
I'm very glad for your responses guys!
I have also now learned that according to Mercedes, they recommend an oil change by 60.000 kilometers (37.000 miles), and never again after that.
And since the history of this car is pretty unknown, I would not be surprised if the original oil still is in there.
I will check with the mechanic if he manages to "check the fluid (Red Safety Lock Cap behind engine near fire wall) just break it off, replacements are pennies on the dollar."
Otherwise I will keep my appointment on the Dec 11 for a flush. I have already bought the oil therefor (20 liters Dexron 6 for about 130 dollars feels like a bargain in this context).
722.6 AMG OEM Stock Speed Shift 240-0106 Valve Body With Bluetop Solenoids – Mk-Ultra Electronics
Auto Trans Fluid ATF 4134 (5 Liters) - FUCHS 800350077 | FCP Euro
I have already bought the oil (Dexron 6).
Veeery exiting to see how the car acts after that...some say there is a risk that I can't even drive it off the lot afterwards!
Even if that happens you just learned a new valve body is only $500.
This M113 engine and 722.6 transmission is one of Mercedes' best ever combinations.
Think about how many '96-'06 cars wore a 430, 500 or 55 on the trunk and let that sink in.
One of Mercedes' best ever.
That didn't happen because people couldn't change their transmission fluid.
Let us know how it goes, and GL.
maw
Nothing against Dexron VI but I'm particular to the point of being obsessive.
maw
Btw, my issue was not about maintenance (could be because of lack there of, but) it has clearly gone way passed that stage...if you read the beginning.
Here's a link to MK-Ultra: Stock Replacement Mercedes Transmission Control Modules EGS52 – Mk-Ultra Electronics You should probably reach out to them. Good Luck!
In my case we haven't checked the TCU, because the electrical contact (socket on the transmission) was fine. I've heard of oil travelling from there to the TCU.
I've seen the blue top solenoids on YouTube. Do they make the gear changes faster, or what..?
Here's a link to a FCP Euro tutorial describing a 722.6 performance upgrade. Rather long as the entire process is shown, but well worth watching even if you have a mechanic do the work. Bing Videos After watching it myself I came to the conclusion my issues were most likely being caused by worn valve body overlap sleeves, but I didn't have the interest / equipment / tools to replace them. So, from both a labor and parts cost perspective finding a plug and play valve body refurbished by a trusted source was a real plus. Install. Adapt the TCU. Done.
Good luck!
Good luck!
I think the high reving from standstill have gotten better now, some days after the flush...at least we think so!
So your car when cold, was also really slamming hard in to second gear...to then shift normal higher up in gears..?
And when warm it shifted normal all threw 1-5..?
How much do these "blue-top-solenoids" cost, and where do I best buy them..?
The link I sent earlier should have been your first clue but.......Genuine and OEM Replacement Car Parts Online | BMW Volvo Audi VW Mercedes Porsche Saab | FCP Euro Good luck man. You've earned "you're on your own from here" status.
TransGo - Mercedes 722.6 SHIFT KIT® Valve Body Repair Kit
The transgo really know what they are doing.
