Steering Wheel function buttons lights not working
Seems like there is an issue and they rather replace a part than investigate. They are not even sure if it is the steering wheel.
Anyone help will be highly appreciated.
Thank you.
Thank you.
new control module is like $150 on ebay
The control module tells the buttons when they need to perform a certain function. when the control module is faulty itll either complely not work or some features will be malfunctioning. replace the module
The replacement process is simple and takes about 20/30 minutes at most unless the screws are stuck (in my case one was stuck). First, you need to remove the air bag, then unscrew the existing control module which has 3 specific screws holding it in place. If any screws are stuck (due to oxidisation) do not attempt to screw them off as you can round off the head (as I learnt from futile attempts by the technician). If any are stuck, then you need to hammer them first to loosen them before attempting to screw them off (the screws seem to be very expensive to replace).
Currently, my steering wheel sometimes squeaks when moved but then goes away. The fault started when the car was laid up during Covid times but now it comes and goes randomly - still trying to figure out what it is!
In my case I have 2 issues, 1 being the backlighting on the controls, and the other being the lane departure . The Code for the lane departure points back to either the Motor that *Vibrates* or the Control Module. Being the backlighting isnt working Im going to assume its the control module or rather *Contact Plate* which is the part you supplied.
There is also a entire steering column (Not wheel) with the stalks that also has a module within it, however those from what I understand (Part Number a2229007608) do not control the backlighting of the buttons on the facia of the wheel, but not sure on the lane assist functionality.
