S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
V12 Missfires
Old Feb 22, 2022 | 10:59 AM
amir1's Avatar
2019 S65 Coupe, 2017 S650 Maybach Convertible, 2020 S560 Sedan, 2022 Porsche 911 Turbo S
V12 Missfires
I am experiencing a lot of misfires on the V12 engine of my S65 Coupe. No check engine light yet, but i'm sure as it gets worse, it will appear. I know Mercedes has had issues with coil packs. I had the same issue on my other v12 Maybach and on my S560. Anyone else experiencing misfires? (engine every now and then runs rough for a second or two. You can easily see the rpm gage needle drop, then stabilize after a few seconds)
Old Feb 22, 2022 | 01:58 PM
haa's Avatar
haa
I see the same thing since day 1 of owning my S65 Cabriolet especially after cold start. No check engine light ever. have around 9000 miles on it
Old Mar 27, 2022 | 08:23 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
My 2007 TT V12 misses intermittently also. It happens mostly on my left side cylenders 7-12 and sets a P0300 P0312 and sometimes a P1170. I can clear the codes and she is fine for a few weeks. Then it comes back. I switched to V12icpack.com coil packs on the left side and I also replaced the voltage transformer with one of theirs. And I run a container of Techron fuel injector cleaner about six times a year. Mostly, my misses have gone. It still happens on gasoline less than 93 octane once in awhile and usually when I am heavy on the throttle.
How many miles on your plugs and coil packs?
Old Mar 27, 2022 | 08:25 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I thought the coil pack issues were mostly on the M275 (older) engines, whereas the newer M279 went to individual coils?
Old Mar 28, 2022 | 11:21 AM
vettebk's Avatar
Absolutely right. My engine is a M275 V12 TT with two coil packs - one on each bank. The newer engines use individual coils. Better design.
Old Mar 28, 2022 | 05:14 PM
amir1's Avatar
My Car has around 8,000 miles on it. They already replaced two coil packs. But there are probably more that should be replaced. It's not my DD, so I need to find time to take it in. Once they figure it out i'll report further. Thanks for the help.
Old Apr 2, 2022 | 05:32 PM
Viper98912's Avatar
If you can't get it figured out, please let me know as I guess I'll have to buy your S65 Coupe from you. At a discount of course, since it's broken.
Old Apr 4, 2022 | 11:54 AM
amir1's Avatar
My BABY ain't for sale. LOL As to the bad coil packs, I might have to pressure the dealer to replace all of them to prevent this problem from recurring. They sort of hinted that they will agree to it if the problem persists. I'm taking a wait and see approach for now.
Old Apr 10, 2022 | 11:11 AM
Jehude's Avatar
2012 S600
V12 random missfire
Great members of this forum,
I just joined and I can say I’ve received valuable information from here than anywhere else. I have a 2012 S600 with 80k miles on the clock. The big girl started misfiring on 1,7 and 9 cylinders
I have fairly adequate mechanic skills and enough tools to change out the 24 plugs but am a bit scared of cracking the delicate coil pack.
So my questions are:
A. Is the misfiring only from the plugs?
B. Should I take it to a shop, give them the plugs to install for me?
Your advice and encouragement would be greatly appreciated.
Jehude
Old Apr 13, 2022 | 05:56 AM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
My 2017 S63 misfired at 70K miles. Luckily I was only a mile from the dealership and they said they couldn't find a problem. I too had just got on the throttle a little heavy and it happened. I no longer have this car but it was fun to drive.
