S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
best spark plugs to use for 2015 s63 coupe ?
Old Oct 31, 2023 | 01:58 PM
PoLo_Jose's Avatar
2015 s63 coupe 2018 s450 ,2016 X6
about to change my park plugs what’s the best i should get .. i herd the stock ones not the best
Old Oct 31, 2023 | 05:42 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
I changed mine from the originals, with 34k miles, and they looked good. I didnt see any reason not to put oem back
Old Oct 31, 2023 | 09:00 PM
PoLo_Jose's Avatar
i have a weird idel sometimes … or it has shut off a few times .. i was told to change the plugs
Old Nov 1, 2023 | 05:43 PM
amir1's Avatar
2019 S65 Coupe, 2017 S650 Maybach Convertible, 2020 S560 Sedan, 2022 Porsche 911 Turbo S
I know sue to smog rules, the V12s idle rough. Not sure about the V8s? Also, MBZ has had issues with coil packs. Spark plugs are usually an easy and cheap first step. I believe MBZ dealers can actually properly diagnose the poor idle issue. Might be the better way to go than just start throwing new parts on the car.
Old Nov 1, 2023 | 07:16 PM
PoLo_Jose's Avatar
good idea .. i’m a call them up tomorrow .. i wonder if there was any recalls on the coils even tho it’s out of warranty i wonder if they would change it
Old Nov 2, 2023 | 05:17 AM
Bigg Willi's Avatar
Veteran: Air Force
| 2015 S63 / 2013 5.7 Tundra |
Use either Bosch or Benz. Bosch makes them for Benz. Although Denso says they have an application for the M157 IT DOSE NOT FIT!, Coils are relatively cheap and you will probably break one or more removing them to access the plugs so just get new ones you can return if not used. And get a dedicated E 8 torx to treat every E 8 coil retaining bolt like you only have 1 try to get it off and on without stripping it. I've done the S63 and the S 550. Not a hard job but very involved. Good Luck...
Old Nov 2, 2023 | 09:13 AM
PoLo_Jose's Avatar
thanks any thought on ngk plugs ?
Old Nov 2, 2023 | 10:17 AM
Bigg Willi's Avatar
Veteran: Air Force
Good plugs, just make sure they fit. FCP Euro carries them, and I might have used them had I known the Densos don't fit. Local import store had the Bosch for the same price, so Bosch went in and the Densos are going back.
For coils I did TRQ, THEY FIT BETTER THAN STOCK, seem to be better quality too.
