2018 s63 amg suspension
I’am currenty driving the new 2018 s63 Amg.
the ride to be honest is horrible, not as comfortable as I expected. I tooked it the dealer thinking that my suspension has problems. But they told me that it is normal for the AMG to be riding hard.
now the question is:
Can I somehow replace my suspension with the normal s560 or s400??
Is there any way to make my car ride more smoothly.
I don’t mind spending more as a comfortable ride is key.
also, can I remove the speed limiter without loosing the warranty as my dealer don’t offer this option.
Thank you
Thank you
Where do you plan on driving the 2018 S63 and the reason I asked is because it tops out at 193mph and you still want to remove the speed limiter?
Enjoy the S63 as it is as good as it gets.
https://www.google.com/amp/s/www.top...74605.amp.html
I have a feeling that my 63 has bad factory suspension, everywhere I read it says The car is on the comfortable side. But mine is bumpy It feels like I am rding a horse 😂. I wish there is a way to know for sure, is this is the how the car spouse to be or mine has a problem. As it is rare to find a car like ours to compare. And I don’t trust the dealer as they say nothing is wrong. As for the limiter mine stop at 165 mph.
once again thank you for the reply
Where are you located and what are the conditions
of your local roads -
I would re-check your tyre pressure -
As S63AMG888 stated above
"The S63 has the most comfortable suspension out of the entire AMG line" -
I would also consider taking the S63 to an alignment shop that uses
weights to replicate the drivers weight ( plus possible passengers weight )
when doing the alignment
and also have the wheels / tyres re-balanced -
I have a friend who was having ride problems with his new E63 -
It turned out one of the tyres was out of round and replaced and
his E63 now rides like it should -
Thank-You
D.B.
If your dealer where you bought it from doesn’t have another S63 for you to test, find another that does even if it means driving 100-200 miles to test it.
As for your top speed, don’t know where your testing it at, but if you have the road and safety to test it and it doesn’t go pass 190mph, make a video if you can and bring it up with your dealer AND MBusa ( if your in the US ).
Best set of luck.
regarding the missfire, they did a software update and mine was fixed.
Your 2018 S63 share the same engine and transmission used on the W213 E63s. Read up, it might help:
https://mbworld.org/forums/w213-amg/...n-options.html
it turned out that the car had faulty alignment. they did an electronic suspension alignment. (just a computer program)
to be on the safe side I did a wheel and tire alignment as well, reduced the tire air pressure.
feels much better now.
thanks guys
thanks guys
What PSI are you running now?
