S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
How to get rid of MB Fragrance
Old Dec 23, 2020 | 03:07 AM
alex92130's Avatar
GL63/GL550/S550/S430
Dear MB owners,
Does anyone have an idea on how to get rid of MB Fragrance inside the car. By mistake, I turned it on to 'test' it, and my wife can't stand the smell (and having a allergic reaction to it). The sad part, is that it lasts a long time (years). Any ideas? (I have tried coffee beans, charcoal, uv and the bottle is out of the glove compartment).
Appreciate your thoughts...
Old Dec 23, 2020 | 05:13 PM
sambam2006's Avatar
GLC Coupe, S63L W222
Have you tried changing the fragrance to something else? I heard someone refilled their empty vial with Creed perfume and that is strong.
I retrofitted the fragrance system in my S63L and it's just one hose that runs from the Air freshener unit to the vents right under the widescreen, if you lift that you will see the hose hole, maybe just put a cap to close the hose hole temporary until you figure something out.
Hope this helps
Old Dec 23, 2020 | 06:35 PM
alex92130's Avatar
Sambam2006,
Thank you for your reply! The 'Creed' concept actually might work, but I will use something that 'washes' out the oils (like alcohol) to clear internal tubing... Will buy an empty vial on ebay and try it.
Happy Holidays
Old Dec 24, 2020 | 12:45 PM
barryrobinson19's Avatar
2016 Mercedes S63 4matic sedan
You can go into the climate settings and turn the system off or set it for more or less fragrance. We have been using Freeside Mood. I know people have tried or are using other chemicals in the fragrance dispenser, however I would think that after a period of time, there could be an interaction between the components of the car and interior trim pieces. Another words the fragrance or chemicals was not designed for the car and interior components. Possible deterioration. Just my thinking. Good luck.
Old Dec 24, 2020 | 02:02 PM
alex92130's Avatar
Barryrobinson19,
Thank you for the response. The fragrance MB uses is extremely chemically stable since system was turned on for maybe a few minutes, but the smell lingers for years now... it is similar to Armorall's smell in terms of stability... Sadly I have an amazing car with almost no miles that sits in the garage because my wife can't stand being inside due to fragrance smell... and the car took too much depreciation to sell (( Wish MB would use something more natural (organic?) in their fragrance choices or at least have half-life in days, instead of years...
Will post if alcohol 'cleaning' will work
If someone has allergies, my advice would be to check the MB fragrance before using it it the car...
Happy Holidays
Old Dec 26, 2020 | 10:05 PM
stever500's Avatar
2025 S63. 2022 911 Turbo S, 23 BMW M5C
WHAT????????? This is the craziest post I have ever seen on this site, ever. It bothers her that much and you took it out of the car? That is amazing to me. At this point, and she must be VERY sensitive to smell, more sensitive to smell than most anyone... I'd bring it to a professional detailer and have them do something with it to rid of the smell. I just don't see if the vial is out of the car, and it's turned off, that it would be this bad where she can't even ride in the car.
Old Dec 26, 2020 | 11:58 PM
alex92130's Avatar
Stever500,
True story. I took it out of the car after turning the air fresher on for a little bit. Wife is VERY sensitive to smells (I literally can't even use 99.9% of soaps, aftershaves etc), I should have taken the container out of the car the minute we got the keys. Professional detailing (several times) by the dealer did not do the trick. Personally, I like the smell...
Happy Holidays
Old Dec 27, 2020 | 08:51 AM
MTrauman's Avatar
'25 S63 AMG E Performance, '26 CLE 53 AMG
You should go buy some McDonald's food like fries and a Big Mac and let it sit in the car for a while. That will get rid of the fragrance quickly! Or find some odor your wife likes and put it in the car. That will help. If all else fails, get a new wife!
Originally Posted by alex92130
Stever500,
Happy Holidays
Old Dec 27, 2020 | 09:54 AM
places's Avatar
No more MB:(
Or just smoke a cigar, then again new wife is not a bad option.
Old Dec 27, 2020 | 03:33 PM
alex92130's Avatar
LOL
McD will not work for me, but "Places" cigar suggestion sounds great Wife definitely stays
Happy Holidays
Old Jan 5, 2021 | 04:32 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
That really surprises me. I can't smell any trace of the MB fragrance unless its actively being dispersed. When I open up the door to the car, it doesn't smell like the fragrance at all.
From everything I have read its specifically designed to not last.
Old Jan 5, 2021 | 08:52 PM
DABRONX's Avatar
E55
Sorry but calling BS. I had used the fragrance and then didn't for several years. The perfume disappeared like any other in a matter of days. It is no special secret formula. It would be impossible to pick that out over the fragrance of the detailing products. Oil is misted and dissipates in the air. Allergic reaction that caused what?
I get she didnt like the aroma as that is a personal choice but as far as it impossible t remove from your car? Come on.
I actually miss not having a car with it in it.
Old Jan 11, 2021 | 01:56 PM
sebdoty's Avatar
2017 G550, 2015 GL350, 2014 S63 AMG
Dear MB owners,
Try using Ozium. They sell it at most pharmacies and autoparts stores and it is very effective at neutralizing the scent. Just spray a tiny spritz into the car and put the AC on recirculate. Leave for 15 minutes and then air out.
