2019 S63 is Amazing but...that Transmission!
Has anyone been successful in having their transmission replaced by MBNA and did that help / fix the transmissions problems??
Thanks.
One thing I've brought up before is that I always use manual mode unless I'm in Comfort. I don't use S+ or Race and let the transmission shift on its own. My theory is that the adaptation gets confused otherwise between my moderate and my spirited driving, so I do all my spirited driving in manual mode, that way the transmission only had to adapt to my moderate driving.
At the end of the day it is a performance transmission and I actually prefer it over a dual clutch, because as opposed to dual clutch transmissions, the MCT can skip gears w/o losing a beat. It drops 5 gears in a fraction of a second when using kickdown for example and if you brake spirited it automatically skips gears while coming to a stop and you can manually skip gears by double clicking the downshift paddle. Sometimes that can surprise with more than expect engine braking when it drops from 5th to 3rd directly instead of 4th and then 3rd.
Superwiss- how long did it take to get the Gear Box to learn to hold the shift to first gear until stopped? That would be a good. And is that only in C mode since you shift manual at all other times?
Thanks all
It is not just in Comfort mode. It's the same when I drive in manual mode. In manual mode the transmission also automatically downshifts if I let the revs drop too much, but when I come to a brief stop I can hold it in second gear (think California/Rolling stop). It doesn't automatically drop to 1st unless I come to a complete stop. It often jolts a bit, though if I let it drop to first on its own in M and anything other than Comfort mode, so usually as I come off the highway where I typically drive in Individual with the powertrain set to the same setting as S+ and transmission in M, I switch back to Comfort as I'm coming to a stop and enter city traffic.
One thing the instructors at the AMG Driving academy told us was not to use S and S+ around town. Those modes are not made for it. They are made for faster and more spirited driving. Going to S+ as soon as you enter a highway is fine, but don't try to use it around town.
I drove a Portofino this past summer for a day. It seemed smoother which surprised me (even my wife agreed who is not focused on driving )...but granted, it was a limited experience.
Just thought this gear box would be smoother in general operation (not noticable when switching from D to P or slowing down for Stop signs or entering/leaving driveway...and snappy / high-performance in S or S+ mode.
The Gear Box was never part of my experience in an S class like it is in the AMG...just surprised
Thanks and Happy Holidays all!
