2109 S65
Trying to see if the 2019-2020 S65 are really the end of the line. Looks like they are for the Amg branded cars but not for the engine as it lives on in the Maybach?
The W223 Maybach V12 is limited to 660 lb-ft of torque because that, 900 N-M, is the warranty limit for the 9sp transmission. Similarly the S65 was limited to 738 ft-lb of torque, 1,000 N-M, because that is the 7sp warranty limit. The rated hp is not affected because it is at an RPM well above the torque peak.
The S65 engine makes 736 ft-lb beginning at 2,300rpm. Therefore the 660 ft-lb limit would likely be at 1,900 to 2,000rpm. Even with the two extra gears the reduced low RPM torque will be apparent in a lot of daily use. When I had my previous S65 tuned (Stage 1, peak torque around 820 ft-lb) the increased torque was very apparent in normal driving.
There is a "Final Edition" for sale right now on BAT that doesn't have the CC brakes but does have the Magic Sky option. I agree with you on the CC brakes. It's difficult to understand how someone can spend a quarter million and not get the CC brakes on such a high performance AMG Limo.
Because I heard the same thing but saw one, I wanted to know how many 2020 S65 sedans were made other than the Final Editions.
https://bringatrailer.com/listing/20...5-amg-sedan-2/
2020 S65 Designo White
