S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
2017 W222 S63 Pre Safe Functions Failure in Heavy Rain
Old Feb 17, 2024 | 10:00 PM
AmrEissa's Avatar
'22 AMG SL63 '12 SLS '17 GLS63 '15 S63 '09 SL63 Silver Arrow '21 GLE350 4Matic
I have a 2017 W222 S63 and anytime there's a lot of water on the freeway due to have rains, I get the following error messages: Pre Safe Functions Failure, Distronic Plus Currently available.
The error messages go away once the car is turned off then back on.
The dealer claims that they can't fix the problem because they can't replicate it.
Any ideas on where they should look to fix the problem?
Old Feb 18, 2024 | 09:16 AM
vincheung's Avatar
S63, GLE580, BV250
Unfortunately, this is normal, heavy rain/snow will cause it to go down from time to time and return to service when it clears up. I haven't come across any threads or info with a solution, I was considering something hydrophobic like a rain-x product on the glass/sensor covers but it hasn't been enough of an issue to be on the top of the to try list. If you do try it out or come across a solution please report back.
Old Feb 18, 2024 | 10:41 AM
AmrEissa's Avatar
Thanks for the reply!
Kindly share the stored error codes that you got.
Old Feb 18, 2024 | 05:03 PM
vincheung's Avatar
S63, GLE580, BV250
Benzninja had done a *thorough scan of my car recently and no module errors stored. Its essentially the sensors going out of service due to the weather conditions which will re-activate once the weather clears, not a module/hardware error.
Last edited by vincheung; Feb 19, 2024 at 12:00 AM. Reason: corrected mis-spelling, through though thorough
