How many of you
So far I've done:
Rear Brakes; rear pads and rotors, swapped rotors to Zimmerman and pads to Powerstop - reduced brake dust by more than 75% - Moderately hard, but not difficult.
Front Brakes: Swapped the pads to Powerstop - reduced brake dust by more than 95% - Easy job.
Front Lower control arm, also called (Spring Link) - Easy just had to borrow friend's torque wrench because the ball joint screw was over 130 ft/lbs.
Oil and filter change - Super Easy
Air filters - Easy
Cabin filters - Time consuming but straightforward.
Fragrance flacon - Easy
Removed 3D Amplifier and renistalled because one speaker wasn't working - all fixed. Easy, just time consuming because of the troubleshooting.
One the list of to-do's soon:
Brake Fluid Flush
Cooland Fluid Flush
Tranny fluid change. I plan to rent the Diagnostic tool that can purge the valves - it only costs $80. Other parts cost a little over $500
Spark plugs: I'm allocating 6 hours and 3 beers for the job. I might split overnight just to reduce the pressure of the moment. Hardest part is indexing the plugs.
Front left strut: Functioning fine, just making noise under heavy compression. It's a problem across many MB models that can persist for years without being a problem, just makes a nuisance noise from time to time.
Hope that helps.
This reminds me of when I changed the head gasket on my MKIII Supra. It all looked really difficult, but in the end it came down to time, patience, and attention to detail...but no real "qualifications". It was much easier and more straightforward than tuning a four barrel carbeurator. I guess the only way to know for sure is to do it and find out.
Attached is a copy of the MB technical note (which has been previously posted on the forum) on the topic of indexing.
I had a 351 in a boat I had, and did motor alignment, valve covers, carburetor.
With my SL, I haven’t done much. I am kind of afraid of it, and it’s still under warranty. Also, getting to a place where I don’t really want to or enjoy the grease monkey ordeal.
