MBUX retrofit for 2020 AMG GT 63
Old Mar 15, 2023 | 05:05 PM
octapups's Avatar
2020 AMG GT 63
Anyone have any luck or experience retrofitting the infotainment system on their AMG GT 63 from the version they introduced in 21. I prevoiusly had a 21 AMG GT 63 (totalled, RIP) and now have a 2020 as a replacement - i thought they were identical (wrong), and the biggest difference so far I see is that the infotainment system is quite a bit out of date feature-wise and is also not touch screen.
Old Mar 15, 2023 | 05:15 PM
Eaton's Avatar
Top Answer: 1
I think it can be done. Ask RJ.
Old Mar 15, 2023 | 05:23 PM
octapups's Avatar
2020 AMG GT 63
thanks for the reference!
Old Mar 17, 2023 | 01:38 AM
mjr24's Avatar
M6 Gran Coupe
I don't see how this can be done short of switching out the entire dash since the pre-2021 is not a touchscreen and the 2020 and older are not.....
I've never heard of MBUX being converted into a non-MBUX car.
Old Mar 17, 2023 | 03:00 AM
Eaton's Avatar
Top Answer: 1
https://m.facebook.com/story.php?story_fbid=pfbid02aK9qwMtxSmwGGWcLEi4WGp9gqUoM9kG8CZziME9VNnj5aknWWRXeCo6UfvXWRzKnl&id=100000154604226&sfnsn=mo&mibextid=6aamW6
Old Apr 8, 2023 | 10:49 AM
kermit frog's Avatar
S212 E250
I wonder how much that costs and how long it takes
Old Apr 13, 2023 | 05:02 AM
W205C43PFL's Avatar
Here is another option someone else mentioned: https://www.mbhouse.ca/store/comand-...rofit-kit.html
Make sure it fits.
Old May 6, 2023 | 02:54 AM
integrale's Avatar
w211 320 sport
it's easy, I did it on mine. I am very pleased with the result. when you sell the old parts the investment is under 3000€. the new system and touch screen are great
Old May 9, 2023 | 04:34 PM
W205C43PFL's Avatar
Looks OEM, was the CEL caused by a module miscommunicating but cleared afterwards after the retrofit?
Old May 10, 2023 | 01:09 AM
integrale's Avatar
w211 320 sport
all parts are original, the car is diesel, and i still can't sync scr module with ic177 and ezs. at worst I will remove the error from the software. But everything works perfectly, and all information and functions are available.
Old May 10, 2023 | 07:13 PM
W205C43PFL's Avatar
I see, thanks for your update. That explains it.
Old Aug 11, 2023 | 03:45 AM
fullvietfx's Avatar
AMG GTS
What new features does the new MBUX have? Does it have full screen Apple CarPlay?
Old Aug 24, 2023 | 12:45 PM
asic_designer's Avatar
AMG GT 53
This system looks like the old MBUX can you post pictures of the new one and tell us the install detaills.
Old Aug 24, 2023 | 12:46 PM
AMG GT 53
Old Aug 26, 2023 | 05:04 PM
W205C43PFL's Avatar
I am guessing they meant they went from COMAND to MBUX, not MBUX 1.0 to MBUX 2.0.
Old Aug 27, 2023 | 02:01 AM
integrale's Avatar
w211 320 sport
Hello, in w213 is only mbux 6, old one is comand 5,5. System is perfect with touch screen.
New whood steering wheel
Old Aug 28, 2023 | 02:20 AM
mjr24's Avatar
M6 Gran Coupe
Not worth the upgrade, IMHO. MBUX 1.0 sucks.....
They fixed MBUX in the GLE refresh and it's a 100x better because it has the full screen Carplay and also has pop up windows so you can basically still go right to the radio even if you are on map view....it's all kind of there on one screen similar to how it is on MBUX 2.0 on the new S class, new C class, etc (just on the dual 12.3 inch screens as opposed to the tablet size of the new S and C).
However, MBUX 1.0 got the short end of the stick.....it was a poorly planned out system and they put all the fixes into 2.0 instead of allowing updates to the 1.0 like they should have.
Old Aug 28, 2023 | 09:20 AM
W205C43PFL's Avatar
There is a MBUX 3.0 on the new E-Class and the new CLE and MB.OS no longer based on NTG (I think?) will come out in newer cars in the form of MBUX 4.0 (?)
Old Feb 7, 2025 | 02:37 PM
Amggt63's Avatar
How were you able to do this and by who? Cost? Interested in doing this. With this upgrade, did you get apps like YouTube the way the latest MBUX has?
Old Feb 7, 2025 | 11:07 PM
carputech's Avatar
SPONSOR
Apple Carplay module for your Mercedes Benz with NTG 5.5, NTG 6.0 and MBUX system.
Don't change your ways, use your preferred applications on your original screen with Carplay .
😃 EXCLUSIVITY CARPUTECH.COM - GET FULL SCREEN CARPLAY! 😃
Waze , Coyote , Siri , Google Maps , Plans , Apple Music , Spotify or Deezer ..., access it all easily from the dashboard of your car with this Mercedes Benz Apple Carplay module. It's even possible to make calls, send or receive messages from your Apple Carplay module while driving ... Steering wheel controls are compatible!
Compatible models:
_ Mercedes A class W177 from 2019
_ Mercedes C class W205 from 2019
_ Mercedes E class W213 from 2017
_ Mercedes G class W463 from 2019
_ Mercedes CLA C118 from 2019
_ Mercedes GLA X157 from 2020
_ Mercedes GLC X254 from 2019
_ Mercedes GLE W167 from 2019
Applicable to all NGT6.0 Mercedes-Benz models
LINK:https://www.carputech.com/products/w...r-link-airplay
Enjoy $30 OFF + Worldwide Free shipping ! (USE CODE: CARPLAY30)
Only for mbworld forum members!
Old May 16, 2025 | 01:56 PM
figuwx's Avatar
2018 AMG E63s Ed1
SO there are lots of things to change
The display cluster from none-touch to touch based
the NTG has to go from 5.5 to 6
Need the Display Module. I heard it called IC176 for the old to IC177 and if you have HUD, the NEW unit must have HUD which i think is the white LVDS connector.
Touch pad
and then need a harness to retrofit from NTG 5.5 to 6.
then you need to code all of it.. might require some major software updates
time consuming but not impossible. EleBest (here and youtube) has numerous videos of the before and after (no how to's regardless of what the title says) on W213 Pre FL to FL.
Old May 17, 2025 | 08:48 PM
EleBest's Avatar
SPONSOR
E200 2010, G63 2018, E53s 2019, EQS53 Touring 2021, S500 2022, A200 2023
Nice job done. Only one little thing, You did not make it perfectly working bro, the issue is the milage shown is - - - - - -
I guess you installed 3rd party adaptor, which naturally got this issue, you can check with the supplier, they may have solution to get the Milage working.
check ours pure original solution with full screen wireless CarPlay.
