2023 GT63: Brake Squeal
Old Jun 19, 2023 | 01:29 PM
sil-abc's Avatar
AMG GT63
Anyone else experiencing their brakes squealing when braking at low speeds? Figured it was expected in the beginning but I’m already at 1500 miles and should be well past the break in period.
Old Jun 19, 2023 | 03:15 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
My GTS does it on stock compounds. Most of the fleet does this down to the V6 and V8 executive sedans. You can switch to ceramic although I don't know why you would on a new car. Tons of metal in the OEM pad, lots of performance and intial torque, they're just loud and it gets worse the bigger the rotors are in the car and less pedal you use. The GLE63's brakes are horrendously loud at low speed stops. On that car you should just brake late and firm when possible. This is not exclusive to MB, the "faster" (lol) Lexus also metal sounds, and BMW's dimpled M Performance rotors have the worst growling noise youve ever heard.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 19, 2023 | 04:04 PM
superswiss's Avatar
2019 C63CS
Brake squeal comes down to bedding the brakes and get them hot regularly so the layer of pad material is maintained. I've driven many different AMGs all the way up to the GT BS and I've so far never had significant brake squeal. With my personal car, the only time the pads start squealing is when they are worn. They start squealing a few hundred miles before the brake sensor trips and then after replacing them and bedding them in, they are silent again. The CCBs however can make noise.
The thing is these cars have performance brakes, and they are not particularly happy if you just tool around the city and stuff with the brakes effectively remaining cold. In the cold state the brakes operate in the so-called abrasive mode and slowly scrape the pad material layer off the rotor until the pads are down to scraping on he bare metal. These cars are really not stop&go, commuter or city cars. You need to drive them in anger regularly and get the brakes hot. Driven the way they are meant to be driven will get rid of the brake squeal.
Old Jun 20, 2023 | 01:31 AM
superswiss's Avatar
2019 C63CS
BTW, in 2018 Porsche put out an educational video on brake squeal, because they get lots of complaints from customers about noisy brakes. It's almost comical to a degree, but the gist of it is that some brake squeal is impossible to avoid in high performance braking systems due to the sheer number of unpredictable influences. Driving style is one of them given that the typical buyer rarely actually does performance driving in these cars.
Old Jun 23, 2023 | 02:11 AM
sil-abc's Avatar
AMG GT63
Understood, thank you for the answers and reassurances. I live in Downtown LA so it's constant stop/go, guess I'll start driving more aggressively lol
Old Jun 23, 2023 | 02:25 AM
sil-abc's Avatar
AMG GT63
2023 GT63 - Parking Assist and PARKTRONIC Inoperative
oops meant to make this a new thread
Old Jun 23, 2023 | 10:36 AM
superswiss's Avatar
2019 C63CS
Yeah, LA is pretty much the worst place to drive one of these. Take it up to the canyons above LA and stretch its legs regularly. You are not doing the engine any favors either just idling along in LA traffic. I'd recommend a more suitable car for the task.
Old Jun 23, 2023 | 09:19 PM
W205C43PFL's Avatar
https://youtu.be/fUNHb9O52WQ
Mercedes-Benz and/or Mercedes-AMG should also make a video on this since it is a very common complaint among owners.
Does BMW and BMW M have one?
Old Jun 29, 2023 | 03:25 PM
W205C43PFL's Avatar
Silence... I guess that is a no.
Old Jul 2, 2023 | 03:55 PM
Vanquish59's Avatar
2019 S63 AMG (Current), 2015 E63S, 2008 E63, 2005 E55
Same Issue on 2019 S63
Same issue im having on my s63, but only squeels loud when brakes are warm.
https://mbworld.org/forums/s63-amg-s...ing-noise.html
