Post your C450 with Aftermarket Wheels
Old Apr 15, 2017 | 01:10 PM
  #501
MBWUSER_0450's Avatar
2016 C450
Originally Posted by AMG-010
What's everyone doing in relation to TPM, are you using the original ones that came with the car (swapping them to the new wheels) or getting new ones and leaving the original TPM with the factory wheels?
Got new ones with the rims I ordered from TireRack. They are 433 Mhz TPMS sensors. The shop I got to install my rims and tires programmed them to the car for me so everything is working as with stock rims.
Old Apr 17, 2017 | 10:49 AM
  #502
thewb's Avatar
SPONSOR
www.wheelsboutique.com
It makes sense to order a new set of TPMS sensors when you purchase new wheels. If you choose to sell the OEM wheels they are more desirable to potential buyers when they know they don't ave to go through the hassle of purchasing new TPMS sensors on their own.
Old Apr 17, 2017 | 11:18 AM
  #503
alexasa's Avatar
c
So, about to pull the trigger on:
19x8 et45 (with 15mm spacer)
19x9.5 et51 (w/wo 5mm spacer)
245/40 F. 275/35 R
OR
235/40 F. 265/35 R
Leaning towards the beefier tires and increased diameter that comes with them (in margin of acceptable difference).
Old Apr 24, 2017 | 01:37 PM
  #504
Adam Schmidt's Avatar
2016 C450 AMG
Fitment Question on C450
Hi Everyone,
I am a new owner of a C450 and am in need of a summer wheel and tire setup. I have been through this thread trying to understand all the fitment questions. I'm terrible at understanding the mechanics of it all.
I have found some wheels with the following specs. I think they will work, but can anyone here confirm?
- F 19x8.5 et 32
- R 19x9.5 et 42
Old Apr 24, 2017 | 01:52 PM
  #505
alexasa's Avatar
c
Originally Posted by Adam Schmidt
Hi Everyone,
- F 19x8.5 et 32
- R 19x9.5 et 42
that rear is likely to poke. You need closer to et50 for the rear on a 9.5
the front will work with a 245 tire, but likely not more.
Old Apr 24, 2017 | 02:57 PM
  #506
2016 C450 AMG
Thank You! By my cals the rear would poke out about .77" more than the factory 18" wheels. .5" for the wheel width and .27 for the 7mm offset variance. Is that correct?
Old Apr 24, 2017 | 03:05 PM
  #507
alexasa's Avatar
c
without overcomplicating things I'm not going to answer that.
Use this:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
basically - find set-ups that work and stock measurements to give you an idea of what you want.
so 20x10 et55 fits the rear nicely. The set-up you have questioned about is 7mm more aggressive and would poke past the fender without rolling/lowering/dialing in camber
tire size also has a huge roll in the equation. So you typically want to compare the same fit that you will be applying.
So, you can run as skinny as 255 (even more but then you're dabbling in that stance life fitment) on a 9.5 without an insane amount of stretch, the OEM fit is 255 on 8.5 (which is considered more of a square fitment).
Even tires vary from brand to brand and those specs can be looked up online too.
This all starts to boiling down to more advance users/fitment.
Basically, I would recommend 9.5 @ et50+ to be safe for the rear with a 265. If you want to fit a 275 you'll want to throw more allowance to fit the more bulgy sidewall.
Then you want to make sure the front and rear fitment make sense as a package. Like, visually, running a 245 on 8.5 up front will look goofy as hell if you're stretching a 255 on a 9.5 out back.
Old Apr 25, 2017 | 01:53 AM
  #508
BMWMB71's Avatar
2016 C450 break AMG Sport
I have 10jx20 ET45 in the rear, and the wheel does not poke, but it is the limit!
Old Apr 25, 2017 | 02:38 AM
  #509
sean1.8t's Avatar
c-fo-fiddy
Wow man! Where have you been!?
What suspension are you running? Any issues with rubbing back there?
Also, what's your front specs?
Old Apr 25, 2017 | 06:36 AM
  #510
BRBM's Avatar
2016 C450
DAMMIT! I know, I may've posted something like this before.......but if only I could've gotten one of these estates in the USA.
I mean, not even by special order?? Sh--. On a brighter note, at least an E400 Estate could be in my future.....thank God Almighty.
[QUOTE=BMWMB71;7126822]I have 10jx20 ET45 in the rear, and the wheel does not poke, but it is the limit!
Old Apr 26, 2017 | 04:37 PM
  #511
BMWMB71's Avatar
Suspension is coilover KW Variant 3. Suspension can be lowered 15mm more, but with 30k miles every year i decided to put it a little bit higher.
Wheels in front are 8,5j ET 42 with 12mm spacers.
Wheels are Ispiri FFR6.
No rubbing issues at all. ;-)
Old Apr 30, 2017 | 10:17 PM
  #512
alexasa's Avatar
c
n/a
Old May 2, 2017 | 02:02 PM
  #513
alexasa's Avatar
c
Hey man,
What part number did you use for this kit? The KW Variant 3's?
Old May 4, 2017 | 09:06 AM
  #514
Big-Omz's Avatar
Mercedes C43 AMG
Need some advice !
Hello All!
I'm new here - purchased a C43 AMG coupe a few weeks ago and just in the process of perfecting it for myself!
So, I'm looking for some nice rims + solid winter tires, hoping to get a good deal entering summer. I'd prefer at least 18s - but 19s would be nice as well - doesn't need to be anything too pricey because they'll just be for the winter months obviously.
As for the tires, I've heard that Michelin X-ice Xi3 or Bridgestone blizzaks WS80 are both solid choices. Thoughts? Costco sells them for about $840 CAD for a set. Is that a decent price?
Thanks for all the help!
Big-Omz
Old May 7, 2017 | 11:29 AM
  #515
PaulC300's Avatar
C300 w205
My c300 w205 Aftermarket Wheels
Old May 8, 2017 | 05:54 PM
  #516
1day6speed's Avatar
500SEL
Would this setup work well for my C450?
19x8.5 38mm
19x9.5 45mm.
Old May 8, 2017 | 06:06 PM
  #517
sean1.8t's Avatar
c-fo-fiddy
19x8.5 38mm
19x9.5 45mm.
You need to get spacers to get the front ET down to 30-32
The rears will be good.
Old May 8, 2017 | 08:47 PM
  #518
1day6speed's Avatar
500SEL
Thanks man, they can make me any offset I want so what would you reccomend for front then 30,31,32? I don't plan on lowering the car.
Old May 10, 2017 | 02:17 AM
  #519
sean1.8t's Avatar
c-fo-fiddy
You know, I'm not positive what is best. I just know that the tolerance for the front on an 8.5" wheel is between 30 and 32. So maybe 30 would be best to have a nice flush-to-the-fender look?
I suggest getting someone else's opinion as I wouldn't take my word on it cause I am certainly not an expert on all this wheel/offset stuff. Just learning myself as I just bought wheel this week.
Old May 13, 2017 | 03:19 AM
  #520
sean1.8t's Avatar
c-fo-fiddy
Can anyone confirm that our lug bolt thread size is 14x1.5?
All my research is showing this but it's usually always showing older cars up to 2015 at the latest. I can't find anything that confirms that 2016+ cars still use that. I'm sure they haven't changed it but I just want to be 100% certain.
Want to order these for my CH-R's that I'm installing next week. Thank you in advance
http://store.blackforestindustries.c...xwhspfor1.html
Old May 13, 2017 | 03:49 PM
  #521
alexasa's Avatar
c
I can confirm that this is correct.
I linked those to you originally with choosing proper spec for your application.
Old May 13, 2017 | 07:19 PM
  #522
sean1.8t's Avatar
c-fo-fiddy
You tha man!
Old May 16, 2017 | 11:30 AM
  #523
Tej7's Avatar
C43 Coupe
I've got nothing to add to this thread. I just wanted to point out that your response caught my attention. You don't see many posts as humble as yours these days since everyone on the internet acts like an expert in every field. Truly admirable Sean
Old May 17, 2017 | 07:31 AM
  #524
BRBM's Avatar
2016 C450
Amen to that Tej7. Speaking for myself, I know a lot about some stuff, but then again I don't know sh-- re: many others like wheels & tire numbers and offsets and such. Always asking my specialist to teach me a little; always learning more.
And yes, while our boy Sean displays quite a bit of knowledge that he is happy to share, he also comes to the table with much the unfilled glass - to paraphrase a Bruce Lee concept - and an open mind.
Old May 17, 2017 | 11:16 PM
  #525
sean1.8t's Avatar
c-fo-fiddy
Damn, thanks guys... makin a dude tear up over here
**Group hug**
