E-Class (W213) 2016 - 2023
Retrofitting Coupe/Conv air vents or not?
Old 07-04-2017, 04:35 PM
vic viper's Avatar
S213
I am torn, should I retrofit the coupe air vents or leave them as is?
I really like the sportier look of the coupe vents but then again the standard ones look very proper and classy.
Another pro is that the open/close flap knob is deleted using the coupe vents.
Having a hard time deciding here, what do you guys think?
Old 07-04-2017, 05:09 PM
joshg1001's Avatar
2017 E300
Personally I like the look of the normal sedan ones. If you end up changing it to the coupe ones, does that mean you will replace the wood dash so that you are without the open/close knobs or will you keep them there as well?
Old 07-04-2017, 05:15 PM
vic viper's Avatar
S213
Yes, in that case I will replace the whole panel, also replace the panel and vents behind the armrest box.
Old 07-04-2017, 08:14 PM
grange3's Avatar
2017 W213
Hi Vic Viper,
i think the new coupe air vents look very cool and if you can change the vents in your car to the new look coupe ones it would make the interior of you car sportier and quite unique, if you go all the way with the job like you are saying please take some pics and post on here for all of us to see.
Old 07-05-2017, 09:59 AM
teksurv's Avatar
EQ
My take is the coupe vents look great on the coupe/cabrio. For the sedan/wagons, I like the originals better.
Old 09-21-2017, 12:55 PM
vic viper's Avatar
S213
And so it begins..
98cruiser (12-18-2023)
Old 09-21-2017, 02:25 PM
petee1997's Avatar
...21 GLE53 24 GLE53
Don't reinvent the wheel. Those turbo vents look great on the coupe.
Old 09-21-2017, 02:33 PM
vic viper's Avatar
S213
Yes, but inside of the car, how do you know its a coupe or a sedan?
arnsbrae (09-22-2017)
Old 09-21-2017, 03:12 PM
arnsbrae's Avatar
Weekend: 2010 SL 350 r230 Weekdays: 2018 E220d Coupe
The turbine vents are great to live with - nice and easy to adjust and point. I also agree they’ll look great in your w213...
Old 09-21-2017, 04:27 PM
ua549's Avatar
It's a coupe if the passengers in the back have bruises on their head.
Old 09-21-2017, 06:30 PM
petee1997's Avatar
I usually count the number of doors.
Old 09-21-2017, 06:45 PM
ua549's Avatar
Hmmm, that CLS400 you have is called a coupe. 4 doors?
Old 09-21-2017, 06:51 PM
petee1997's Avatar
Calling the CLS a coupe does not make it a coupe.
Old 09-22-2017, 12:32 AM
vic viper's Avatar
S213
There is also a practical advantage to the swap, in the "knob style" flap adjuster it is sometimes hard to select a flow value of about 50%, the knob tends to go back to fully open.
Old 09-23-2017, 02:05 AM
Mbracer26's Avatar
Past 03 SL500,03 C240, 07 E350, 07 ML350, 10 ML350,11&14 E350 X2 2017 E300, 2017 C350e & 2000 S500
So you are saying you can close off each vent off instead two at a time? If so this would solve the annoying slow airflow out of the center vents. They don't even hit your face to cool you off.
Old 09-23-2017, 02:55 AM
vic viper's Avatar
S213
Yesn, they are individually adjustable.
Old 09-25-2017, 07:32 AM
vic viper's Avatar
S213
Parts keep coming in
Old 09-25-2017, 05:33 PM
Mbracer26's Avatar
Can you only change the vents and leave the wood and adjuster lever in place?
Old 09-26-2017, 12:23 AM
vic viper's Avatar
S213
Dont think so as they are different sizes, but Ill look into that while swapping.
Old 07-31-2018, 04:56 AM
mcflo's Avatar
S213
Hi Vic,
has this been taken further?
Did you retrofit the coupe air vents?
Looking forward to do the same.
Do you have a hint on how to change the outer air vents near the windows?
Thank you
Best, Florian
Old 07-31-2018, 08:46 AM
vic viper's Avatar
S213
Originally Posted by mcflo
Hi Vic,
Thank you
Best, Florian
https://mbworld.org/forums/e-class-w...air-vents.html
Quick Reply: Retrofitting Coupe/Conv air vents or not?
