Bullet Performance W205 C63 & C63S (2015+) Downpipes
Our Mercedes Benz (W205) C63 & C63S (2015+) downpipes were designed from the ground up by Bullet Performance talented fabricators to offer excellent fitment on your Mercedes Benz (W205) C63 & C63S (2015+) while getting your aggressive build, big-time horsepower and torque. Each set of downpipes features tubing that's all precisely mandrel-bent to greatly reduce back pressure and allow for much more efficient exhaust outflow than your factory exhaust pipe. The downpipes are made out of high-quality 3 inch diameter stainless steel that can resist corrosion and discoloration in practically any climate or application.
Highlights
• Peak HP Gains: + 11 hp
• Peak TQ Gains: + 10 ft lb
• 3.0" mandrel-bent tubing for optimal airflow and acoustic performance
• T-304 Stainless Steel Tubing
• TIG Welded and Backpurged
• Engineered, designed and manufactured in house at Bullet Performance
BUY NOW
(In case payment was declined: We Use Secured Payment Gateway which might require you to contact you card issuer for approval and payment to go through)
Pictures?
you mention mandrel bent, would like to see as if that is the case, you'd have a huge advantage in airflow to many out there that are utilizing multiple pieces welded together to create their bends.
what gauge stainless steel?
I would like to know as well, are the dp 1 pc mandrel bend or numerous mandrel pipes welded together?.
Those are bolt-on direct fit. I have established a Promo Code for forum members for a 15% off till the end of this month. Use promo code MBWorld15 in your shopping cart.
Those are made to order and should ship in 7-10 days after payment.
Picture uploaded. We use welds between the bends not in the bends (not pie-cuts). And we use Stainless Steel 304L 16-gauge
Just purchased these downpipes( 114 WHP, with only downpipes and a tune). They fit PERFECTLY. Great job by the boys at Bullet. Money well spent, couldn't have asked for a better experience. Would recommend any one who wants great sounding downpipes for their car.
