Stuck in Sport Mode
Stuck in Sport Mode
Hi all,
I just purchased a 2012 E550 a207 black with red leather. Way more powerful than my CLK550 convertible, and I love it, but the sport mode is a little bumpy on some of the roads I have to drive on and I cannot seem to disable it. I'm referring to the sport mode available with the dynamic handling/suspension option, not the transmission setting. The red LED for sport mode is always on and when I press the button on the dash nothing happens. Tried switching the car off/on, stationary, driving, but I cant seem to disable sport mode. I'm taking it to the shop for them to check but thought I'd ask here in case anyone knows of this issue.
Cheers
Cheers
I fail to see what the problem is with being stuck in sport mode. lol
I'm with previous poster. Battery disconnect and if not a trip to the dealership might be in line.
its either 1 of 2 things.
first one would be battery had died or weak and it is charging the battery until its stable. the car will be stuck in sports mode usually if the battery had died for awhile and has been recently jump started.
second one would be after market shocks are installed which would cause the oem shocks to be disconnected causing the car to be in sport mode all the time. or one of the shock are disconnected. open the hood and look at the shock mounts and see if everything is plugged in.
Mercedes E350 CD Iridium silver convertible 2010
GO into the command engineering menu and do a system reset!!! You can also check for error codes to see if you have a real issue..........buttons tel.off plus #, plus 1 all pressed together with the key in position 2 (engine still off).
You can do a system rest!!!
You can also do a number of checks here, then once in this menu do buttons tel.off, plus #, plus 4 hold all together till the engineering menu comes up !!!!!!
Do not change any setting unless you know what your doing!!!!!!!!!!
Thanks for all the replies.
Checked for after-market shocks and the ones installed are black and look stock
Checked that wires were plugged into the top of the shocks - they are
Disconnected the battery - no change![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Checked the Command system and the only error is lots of "FBAR not connected" logs which is apparently something to do with the DVD system
Taking it to the dealer tomorrow
E550 Coupe
Did you ever get this resolved at the dealer?
Sigh... My coupe recently started doing this too, it's now stuck in Sport mode. I guess first thing I'll have checked out are the front shocks.
EDIT: SOLVED!
EDIT: SOLVED!
Suck in sport mode
How do you do a system reset. Im in Engineering mode. Sport mode came on my car started up weak it did it once before then went off. Havent start it in a few days had eye surgery
Hello people,
My W204 350 cdi has developed a similar problem with the sports button coming on whilst driving and me only being able to turn it off when the engine is off.
How did any of you solve the problem??
1 Post
2014 E550 Cabriolet
Position sensor
Mine was doing the same thing. There are sensors at each wheel that mesure the movement of the suspension. They have a plastic arm that snaps to a bracket with a metal ball. The little metal ball was rusted on my Canadian car and it ***** out the inside of the plastic arm. It would fall off and since the computer can no longer mesure the movement at the wheel, it goes to sport mode the second you start to move the car. I lubricated all 4 little joints and used Teflon tape to compensate for the loose at my left front wheel. No issues since over a year of driving. I recommend that spray lube be used once a year so the joints do not rust and start to grind themselves.
RealDonn (07-06-2024)
Seems to be a battery in my case: no issues today and it was fine on my way home yesterday. Just in case I checked the wires on the sensors, everything is good. Thanks for heads up!
P.S. shopping for a new battery
![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
2013 E550 Coupe Designo
I am not finding that part number. I have a 2013 E550 Coupe stuck in sport mode. The battery is topped off. The scanner shows low voltage to the left rear lateral acceleration sensor, which I have replaced. Yet after replacement, the car still goes into sport mode for periods of time.
Received 4,444 Likes
'71 Pinto
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/581x687/capture3_efb49be3990f6c3bc2e57e0fd8deb49945f42fe8.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/1475x731/capture_cbd34163a0c9fd41fdfbd3f46206d6ef9c26fe5f.jpg)
mrmotoguzzi00 (12-06-2019)
