C43AMG Wheel Spacers
Hey guys,
Just ordered a C43AMG with the 19 inches AMG Split 5-spoke bi-color wheels. Just wondering if any of you added spacers to the car? How's the look, can some of you post pics! Also, wondering if it will affect the handling or something.. I want it to look a little more wider from behind.
Thanks guys, can't wait to receive my car
Will do! But why did you use the same spacers size in the front and in the back? Would've thought the spacers in the front were less usually.
thinkbig12 (02-06-2017)
I measured the gap on all (4) wheels and determined that a 15mm spacer was probably the best offset. Gap was pretty close from back to front so I get the need for not necessarily needing to stagger. Now, can somebody provide the correct part number for preferably H&R bu maybe Eibach as an alternative? Neither list our vehicle on their website.
Hi
need some wheel spacers for the rear of my car
does anyone know what type I need or anyone have any pics or contacts to where I could purchase these as need them asap
thanks
thanks
Anything above that you should be fine. I'd personally stick with H&R.
I have 12mm up front and 15mm in back but I'm running 19x8.5 all around (ET34 Front, ET42 Back) here is a pick:
Hi - my car is sitting on 19's and I'm considering buying lowering springs with 12mm spacers for the front and 15mm spacers for the back, just like what you have. Did you need to purchase extended bolts to make sure the spacers and tires were secured?
Springs:
https://www.ecstuning.com/b-h-and-r-...gs/28811-2~hr/
12mm Spacer:
https://www.ecstuning.com/b-h-and-r-.../2455665sw~hr/
15mm Spacer:
https://www.ecstuning.com/b-h-and-r-.../3055665sw~hr/
Springs:
12mm Spacer:
15mm Spacer:
Anything between 8mm and 12mm you're going to be in trouble (there will be no "lip" for the rim to sit on). for 12mm you'll need H&R specials (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1)
Springs:
12mm Spacer:
15mm Spacer:
Springs:
12mm Spacer:
15mm Spacer:
Cracks450 (05-19-2020)
Ultimately it's a lot of money to spend for mostly aesthetics, I'd take your time and make sure you get your stance and fitment dialed in perfectly. Figure out the up and down part first, then decide on the right and left.
