H&R Springs vs AMG Sport Springs
Old 06-02-2017, 04:03 PM
2007 E Wagon's Avatar
E Class Wagon
Hello All,
I am interested in lowering my C300, however I am concerned that if I was to purchase lowering springs, it would not lower that much compared to the Sport Suspension. Is this true? Anyone with a C300 Sport and lowering springs, I would like to see a picture of the car after lowering it. Thank you all for your time.
Greg
Old 06-02-2017, 05:27 PM
Jones88's Avatar
C180 S205 AMG Line Arrives Sept. 2016
The spring manufacturers drop specs are from stock springs.
However i used Eibach pro kit and it still lowered the car about 2 - 2,5cm.
I also run spacers, 10mm front axle and 15 rear. Looks awesome!
Old 06-02-2017, 08:07 PM
applehaus01's Avatar
C300
Jones- can you post pics pls. This is on my mod list. Thanks mate
Old 06-03-2017, 03:51 PM
Jones88's Avatar
Sure
Old 06-03-2017, 11:26 PM
C300
Very nice set up Jones! 18" rims? Next time I'll get a wagon.
Old 06-05-2017, 10:36 AM
Jones88's Avatar
I am really happy with how it turned out! Its the OEM 19" multispoke.
Old 06-05-2017, 11:52 AM
C300
Was it necessary to add the spacers or just to bring the wheels closer to the fender?
Old 06-05-2017, 01:45 PM
jatt143's Avatar
2018 C63s AMG
I highly suggest you don't get H&R springs, myself and couple others have an issue where after a month of use H&R springs are squeaking every time you go over bumps.
Old 06-05-2017, 04:12 PM
Jones88's Avatar
No not necessary, just to get wheels closer to the fender as it looks so much better imo.
The squeeking can also accour with the original springs, its a TIPS message for that problem at your dealer. Some dealers might blame the lowering kit, and you may have to lube them up yourself. Its a yellow rubber bit inside the struts in the front that gets dry over time.
Old 06-07-2017, 02:01 PM
Randy Toro's Avatar
c-class 300 w205
I jones I just got my 2016 c-class w205 and installed a set of 19inch wheels staggered, but is your spacers hub centric and do they have the lip on the spacers to seat the wheel hub on the run hub tigh ? And do they vibrate when you're driving 70 mph .
Old 06-08-2017, 02:08 AM
swaysway510's Avatar
2008 Mercedes-Benz C300. My other ride is a 92 240sx vert.
I have an 08 c300 on H&R super sports, I think it looks good but I'm just about to buy some H&R sports because the supersports I have are too low. So low that I've gone through 3 tires on just the front passenger side. I make a lot of right turns and it got so bad that the fender is cracked now lol. but the ride is pretty smooth and handling is great. No squeaking at all btw. over a year old and about 15k miles on them.
Old 06-08-2017, 02:05 PM
Jones88's Avatar
Yes my spacers are hub centric and have a lip to seat the wheel correctly.
No vibrations at all! The rears are H&R
Old 06-13-2017, 03:08 PM
toufic84's Avatar
Mercedes C250 - W205 - 2015 Model
Hello All,
I am interested in lowering my W205 C250 2015 model about 35mm to 40 mm, i am not sure which lowering springs to buy; I am seeing a lot of threads about H&R springs, so can anyone please advise from where to purchase; and shall I also change the shock absorbers or just keep the stock ones;
other suggestions are also welcomed.
thank you
Old 06-24-2017, 07:52 AM
Tim B's Avatar
2017 Mercedes-Benz C300
Are you currently use the OEM shocks with H&R springs? Any problem?
Old 06-24-2017, 01:09 PM
mbC300guy's Avatar
C300
im waiting for my H&R Sport springs to be delivered, putting them on a c300 sport sedan w/ 20" vossen cvt wheels. Will everything be ok?
Old 06-25-2017, 12:57 PM
Jones88's Avatar
Yes I use OEM shocks with lowering springs, but they are Eibach.
No problem at all! I actually think the ride is a bit smoother and it sits better at turns.
Old 06-25-2017, 06:57 PM
Tim B's Avatar
I'm looking forward to buy Eibach Pro Kit springs and use OEM shocks. I'm afraid the OEM shocks will go bad after awhile, as the performance shop told me. How many miles or how long have you been driving with them, so far?
Old 06-26-2017, 11:17 AM
Jones88's Avatar
I dont think they will go bad any quicker then normal. They sit about 2-2,5cm lower than normal (AMG line), and that doesent wear the shocks any more i think.
I got 3000km in, and no problems yet.
Old 06-26-2017, 12:38 PM
l3gendary's Avatar
C300 sedan
You'll be fine with the Eibach's "Tim B"
I know it's not apples to apples comparison but Eibach's are really well known for their "OEM" qualities. I came from the f80 m3 previously and they actually did a lot of the BMW ones direct. They don't go super low like the H&R but provide a comfortable ride. I see no reason why the oem shocks will go bad within the term of a lease (45k miles etc) for a moderate drop. Get it and post some pics! That wheel gap has gotta go lol
Old 06-26-2017, 06:21 PM
Tim B's Avatar
Thank you, guys!!!
Quick Reply: H&R Springs vs AMG Sport Springs
