C63/C63S AMG
Steel braided brake lines ?
Old 07-13-2017, 08:21 AM
juse's Avatar
c63 coupe
Have anyone installed that or maybe know where to order?
hotdognobun (05-01-2024)
Old 07-19-2017, 07:19 AM
C63s1edition's Avatar
W205 c63s edition 1 coupe
I would like to know as well!
Old 07-20-2017, 11:36 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Stock rubber lines are pretty robust and stand up well to 20 to 30 mins of the track use. SS brakes line will not improve pedal feel on the W205 chassis.
I would focus more on brake pads.
Old 07-20-2017, 12:16 PM
SuckaGDog's Avatar
C63 AMG Black Series
http://www.racingbrake.com/Stainless...-p/rbl-043.htm
Racing Brake offers them.
juse (07-20-2017)
Old 07-21-2017, 01:11 AM
juse's Avatar
c63 coupe
Of course its not only about brake lines
You should use new brake fluid
the motul rbf 600 is a good one
duet of motul + ss line will give you much better response to a brake pedal
Old 07-23-2017, 05:32 AM
Lak76's Avatar
C63s
Pads
I suggest you also use Pagid Racing Pads RS29 otherwise the original ones will be finish in couple laps. I do 3 track days with my car and the first one I made all OEM it is very bad. For the second I change pads,brake fluid and made steel brake lines the improvement are awesome.
Track at Interlagos - Brazil
Old 07-23-2017, 12:14 PM
larrypmyers's Avatar
16 GLC 19 Volvo XC40 06Corvette Z06
Unless your intending to track your car the modifications your asking about are overkill.
Further, these mods. will have no effect on pedal feel. On the other hand, track pads will make a big difference.
Old 07-23-2017, 12:44 PM
juse's Avatar
c63 coupe
you mean RSL29?
you use them with default disks?
Old 07-23-2017, 01:24 PM
Lak76's Avatar
C63s
Pagid
you mean RSL29?
Yes in this moment I use but in the future I will install Brembo Racing brake discs is more efficient and cost less.
juse (07-24-2017)
Old 07-23-2017, 02:17 PM
you mean RSL29?
juse, No need to apologize for your English. It's fine.
Much better than my second language. Ahh, perhaps that's because I don't have a second language. One of disadvantages of speaking English in North America.
juse (07-24-2017)
Old 07-23-2017, 06:39 PM
SuckaGDog's Avatar
I suggest you also use Pagid Racing Pads RS29 otherwise the original ones will be finish in couple laps. I do 3 track days with my car and the first one I made all OEM it is very bad. For the second I change pads,brake fluid and made steel brake lines the improvement are awesome. Track at Interlagos - Brazil[/i]
How did your caliper finish hold up at those temps? Any color fading or peeling?
Old 07-23-2017, 07:38 PM
Lak76's Avatar
C63s
calipers
They finish perfect without issue in color or peeling the only issue that I had was if the brake discs the crack in all surface.
Old 07-24-2017, 06:57 AM
juse's Avatar
c63 coupe
Could you share a link please?
Old 07-25-2017, 12:34 AM
Lak76's Avatar
C63s
Link
Do you mean link for Brembo Racing?
i don't have it is racing rotor and I will made the disc bell on my own.
The disc code are 59B97914/24
The following 2 users liked this post by Lak76:
juse (07-25-2017), Star4life (08-23-2017)
Old 04-30-2024, 10:58 PM
2020C63s's Avatar
2020 C63s coupe
yes exactly what i experienced !
Pagids brake pads, new brake fluid , and stainless steel brake lines and ur good to go!
Old 05-01-2024, 04:17 PM
user33's Avatar
SS Braided Brake Lines for C63 S (and others)
I put these on my 2016 C63 S and found that, especially on the track, the brake pedal was noticeably firmer feeling:
https://www.probrake.de/Stainless-st...014-10-2022-12
The fitting wasn't exactly the same as the OEM fittings so I had to be careful to orient/route the lines to prevent any rubbing, etc. I also "unwound" the "metal spring" cover off the OEM lines and installed them onto the braided lines, for extra protection. If you send them a picture of the fitting ends on your car, you might avoid the slight difference in line construction (the SS braided lines either had or was missing a curved end, IIRC ... still worked but you did have to tighten with the correct orientation).
Quick Reply: Steel braided brake lines ?
