E300 Perfume
E300 Perfume
I just picked up my E300 yesterday and have the perfume set to medium in the car. Is the smell supposed to be hardly noticeable?? I think i smell it if i have the vents shooting out the air to the body section instead of the floor, but It might just be in my head.....? I am sure I have it turned on in the system.
2018 E300 4Matic.
It's subtle ... very subtle. Sometimes when you start the car ... but not always. Mine's also set to Medium.
At least you also get Air Ionization with Air Balance. I always leave it turned on.
I don't know what triggers perfume distribution, and how often. Does anyone know?
In my C300 that had it I noticed it often when I accerated. Also as Bellevance noted, when I started the car. There are some conditions though that are required, for example you can't have the "recirculate cabin air" button selected, and if I recall I had to have the driver's air vent open. You might look in the manual.
Akso it took me forever to realize that I was turning it off. I have played with the control in the E but in the C the circular symbol it wasn’t obvious that I had to have it set a certain way and if it wasn’t it was actually off
jhpmbusa (01-03-2018)
Silly as it sounds make sure you removed the plastic tape it might have had over the cap. Also you should hear it rise up when you close the glove compartment. As I mentioned you need to make sure you don’t have it on recirculate. Make sure all vents are on and open. Turn off the ionizer and see if that makes the scent more noticeable.
Will give it a try tomorrow! I believe I have the IONIZER on, hopefully when I turn it off it should work. What does the IONIZER do anyways lol?
I could not smell any perfume in my new car. The dealer looked at it and send it was working just fine. I still could not smell anything, It would be better to buy a $1.95 pine tree smelly thing and have the extra space in the glove box.
The following 2 users liked this post by 704set:
forecastdude (10-13-2019),
Joshua (10-27-2019)
So I finally gave the dealership a call today. Seems like it works when I put in on AUTO. For those that said it works do you guys leave the air/heat on AUTO?
Thanks,
704sey
Oh, that AUTO. I always have the Auto on and it doesn't seem to affect the perfume. I don't think I will be spending $95 for a perfume refill when the $1.95 pine tree works better.
Thanks.
Thanks.
Joshua (10-27-2019)
Yes, it's also noted in the manual (page 125 of the manual): "Automatic climate control is activated." As I said earlier in the thread, it takes a whole set of conditions for the Airmatic to work. It does work though. I purchase my own scents and use the refillable bottle. Using white vinegar and coffee beans between scents to try to reduce the previous scents effects. As for the $1.95 freshner mentioned later, yeah no I'm not putting a $1.95 freshner in my 86K car.
And you are correct about putting a $1.95 pine tree freshner in a $86K car. Next time I'm putting in an entire pine tree for $95.
704set
Did you get this working? There are a few cases where the scent hose behind the glove compartment got pinched during assembly thereby preventing the scent from coming out of the vents.
oh excellent! yes i still feel like my issue hasn't been resolved. Whats the best way to tell the service department on fixing this issue???
2015 ML350+2021 E350
Ionizers (supposedly) improve air quality by removing particles from the air in the cabin. Separate from that is fragrance. I have my fragrance setting on low, and it works as expected, although I can't tell you how or when. Usually just after start up, and then at random times thereafter. Fireside (the default fragrance that come with the car) is gently emitted into the cabin. The odor lasts for a short time and is rather pleasant. i don't smoke or have pets in my car, so there isn't much to mask. BTW, I run my climate control on Auto nearly all the time, set at 70.
Try following the instructions on page 125 of your operator's manual again first under Perfume atomizer
Setting the fragrance system
Requirements
R Automatic climate control is activated.
R The glove box is closed.
Multimedia system: Vehicle --> Climate Control --> Air Freshener
To set the intensity: select HIGH, MEDIUM, LOW, or OFF
Try that first and see if you can smell it. Even on the low setting, the scent is noticeable unless your sense of smell is severely impaired. If you still don't smell the scent, request your dealer to check it again and say that it's not working. Tell your service advisor that you've heard of cases where the scent hose was pinched during assembly and have the tech or even better, the shop foreman, research the issue in his resources as it's not an official MB service bulletin. He should know where to look for the cases and remove the glove box to check the scent hose.
First of all, is it working for you? You said in a post above that it seems to work in AUTO mode?
Requirements
Requirements
Just got my car back after 3 weeks, states that the perfume is working as its designed. Still not a single smell after having it all weekend long. Is it possible for me to fix on my own?
Put it on high in settings and see if you can smell it. For us, it was too prominent in High, so we backed it down to low and it's there, but just barely as I think it should be.
