Any windscreen washer recommend?
BoMB (07-18-2024)
do not use any hydrophobic compound on your windshield, period. They react very negatively with MB wipers. You can use them on any other glass surface. I use MB summer and winter fit exclusively. They are a ripoff but they work very well. If in europe buy the gas station pink soapy fluid, it works great in summer. Wiper fluid in the US is uniformly ****.
Received 1,503 Likes
I don't think it's the auto sensing wipers, it's the low windshield washer fluid sensor. Had to replace it on my W212, it looked fine though, wasn't gummed up like you might see on youtube. Some claim that the ph isn't quite right unless you just use regular windshield washer fluid. I just get the regular blue stuff at Walmart.
Sorry for the mistakes . Actually I'm asking about the windshield washer which put into the container , not the shampoo to wash the windshield . I mean the what fluid will put into it . I ask dealer he say they put MB original windshield washer . Can we buy it in the market?
M-B washer fluid comes as a concentrate known as Summerfit/Winterfit. Unavailable at the dearer, instead, purchased on Amazon. Following directions for dilution, one ends up with a gallon of fluid costing $8.00. Way over priced. It does, however, work very well. Has somewhat of a soapy consistency as it goes on the windscreen.
How important is using M-B branded fluid? Not much in my view. Washer fluid is not rocket science, therefore, brand is unimportant. Pick your poison.
In talking to the dealer service manager he advised me of a service bulletin stating not to use Rain X as it had a tendency to foul the reservoir guantity sensor. Additionally, he said the shop uses the same fluid one can buy at Wallmart.
In the winter, as I drive to Vermont, I look for a fluid that is good to minus 30. All other times one good to minus 20.
I have never found one fluid better than another. I always buy the cheapest on sale - it is only windshield wiper fluid!
Mercedes says use Summerfit/ Winterfit especially in applications with headlight washers as they aren't harmful to the headlight lenses. I don't have headlight washers, but I still use their Summerfit mixed w/ a gallon of water.
Harmful to headlight lenses?
As John McEnroe often said "You've got to be kidding!"
Do you take you car to a car wash? I do and nothing has ever happened to my headlight lenses.
If you are truly concerned put a coat of wax or Rain-X on the headlight lenses. That will not only keep them clean but protect them!
due to unsuitable windshield washer fluid
Unsuitable windshield washer fluid may damage
the plastic surface of the exterior lighting.
# Only use windshield washer fluid that is
also suitable for plastic surfaces, e.g.
MB SummerFit or MB WinterFit.
I have seen hundred of cars that have hazing on their headlights. Not one of them had headlight washers!
The hazy is caused by oxidation and UV - not the type of washer fluid you use.
As I said put a coat of wax or Rain-X on your headlights - I do and they stay remarkable clean. I also do the rear tail lights as they are also plastic.
If you do have hazing problems, there are many products made to correct the problem:
see: https://shop.advanceautoparts.com/p/...5&gclsrc=aw.ds
windshield
windshield
windshield
windshield
Dear Camaroguy72:
Here is where I think we are:
What did you think your Mercedes adviser would say: Save a lot of money and use Rain-X instead of the more expensive MB SummerFit or WinterFit that he sells?
As most of us do not have headlight washers it seems, at least to me, you have a solution (using the more expensive MB SummerFit or WinterFit) looking for a problem!
- You are worried about crazing not hazing on your headlight assembly when windshield washer is use.
- You do not have windshield washers on you car
- Your Mercedes adviser recommends either MB SummerFit or MB WinterFit to prevent crazing or is it hazing on your headlights?
I said mine doesn’t have it but I use it anyways. I got 6 summerfit bottles for $12, add a gallon of water at $0.80 - $2.80 a gallon. And the owners manual says to use one safe for plastic surfaces.
Received 1,755 Likes
2016 E350 Sport
Six bottles of SummerFit for $12 ($2 each) is a great price. WHERE, please?
On Amazon:
$15.88 for one liter for WinterFit
In answer to question of how much to use, the following was posted:
Is there any wonder the Mercedes service adviser recommended WinterFit!!!!!!!
see:
In graphics on bottle: 2 parts water to 1 part Mercedes cleaner. Distilled water is suggested.
If that is true, than 1 liter plus two parts water is slightly less than a gallon which means a gallon will cost more than $17.50 or more than 8 times what I pay at Costco for Rain-X!!!Is there any wonder the Mercedes service adviser recommended WinterFit!!!!!!!
see:
Just found this:
1 to 1 ratio of Winterfit gives protection to -20C which is -4 Fahrenheit
So to get protection to -25 Fahrenheit I think you would not dilute it. ( drive to Vermont skiing and need protection to -25F)
The site below has it for $8.64 plus shipping. Pretty expensive!
see: https://www.benzparts.com/oem-parts/...e-002986147109
There are quite a few listings on eBay for SummerFit. Like 12 bottles for $20 (but $10.40 shipping), making the price per bottle $2.53 each, which isn't too bad. Or 6 for $16 plus $10.40 shipping, or $4.40 per bottle.
