E-Class (W213) 2016 - 2023
Navigation reading in mph but really in kph
Old 03-03-2020 | 08:16 AM
iaincampE400's Avatar
2017 E400 4Matic Wagon
When using ApplePlay on an iPhone, running Wayz, plugged into the MB USB port, and providing data to the MB navigation screen, everything is correct except that it shows me going 100 mph, when I am actually going 62 mph, etc. Given the multiplier, I assume that I am seeing my kph, but I am at a loss as to how to remedy. Any ideas?
Old 03-03-2020 | 03:48 PM
DFWdude's Avatar
2016 E350 Sport
Since you are seeing 62mph on your car's speedo, my assumption is a KPH default setting in either Apple Carplay, Wayz, or possibly the iPhone itself. I would check settings in all three.
Old 03-03-2020 | 03:59 PM
superswiss's Avatar
2019 C63CS
Well, does it actually say mph or km/h on the screen below the speed? My guess is your unit setting is wrong in the Waze settings under General. Make sure it's set to Mile.
Old 04-26-2021 | 10:02 PM
Fred CoolOut's Avatar
300 e
Same problem
I have the same exact problem, did you ever solve it?
Old 04-28-2021 | 02:27 AM
KatanaPilot's Avatar
2018 X166 GLS550, 2017 S213 E400
I had the same issue. A dealer software update fixed mine.
Fred CoolOut (04-28-2021)
Old 04-28-2021 | 01:43 PM
300 e
May I ask which model and year is your car?
Thank you.
Old 04-28-2021 | 02:53 PM
Thank you.
Hi Fred,
Mine is a 2017 E400 Wagon. I purchased the car as a CPO 5 months ago, and the car had the original COMAND software from 2017.
It had numerous issues, including this MPH/KPH issue with Waze.
My dealer updated the COMAND software to latest available, and it fixed the Waze MPH/KPH issue. Therefore I concluded that the problem was with the car software, not with Waze or Apple CarPlay.
Check to see if you have the "Disable NFC" option in your menu. If you don't, then you have an older version of the software.
Hope this helps!
Old 04-28-2021 | 03:01 PM
300 e
Hi Fred,
Hope this helps!
Thank you. 🙏🏽
Old Today | 02:14 AM
2017 MB E300's Avatar
Hi Fred,
Hope this helps!
2017 E300, same issue. I’m out of warranty and my dealer won’t do anything free. A workaround is buying a wireless CarPlay adapter, that fixed the issue for me.
Quick Reply: Navigation reading in mph but really in kph
