Need some help on fuel gauge problem.
I have a 2016 e350 with 25k on it. I pulled over to get gas put 20 dollars in it and when I started driving i noticed my fuel gauge was reading empty and service engine light was on. Any ideas on what this could be?
Received 1,008 Likes
'11 E350, '11 E550, '98 M3, '95 E320
Was it reading empty when you pulled over for gas? Reserve light on? Have access to scanner to pull codes? Did the CEL only come on that time or is it still on (if you've driven it since)? Otherwise its a guessing game and $20 of gas is irrelevant as prices are all over the map depending on location.
I just hit low fuel when I pulled in to get gas. When I left it showed almost a half then about 3 mins later I looked and it was showing on empty but no low fuel light and the check engine light on. The check engine light is still on and fuel gauge on empty but car running fine.
pierrejoliat (12-31-2020)
Received 4,448 Likes
'71 Pinto
P206600 - The right fuel level sensor has a malfunction. Need to remove module and replace sensor shown part # should be 2045400717 need VIN to confirm.
Received 1,160 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
before you go buy a bunch of parts, turn car off at home , put foot on tire and rock car back and forth on the park pin until you hear the fuel in the tank sloshing, do this for 3-4 minutes, then put key in and see if gauge goes up, Just guage, light might go out after driving awhile, or you can clear it with your new code reader. this worked on my "07 S Class, just sayin'
KEY08 (12-31-2020)
Alright I am going to try rocking it back and forth maybe that will work. My vin is WDDHF5KB7GB271008.
'71 Pinto
2045400717 is correct part #.
Some scanners (Xentry for sure) will show frequency of code setting... you can determine if it's a one off situation or a persistent issue. However I agree with @pierrejoliat , scan for codes (write them down), clear codes, see if they return, rock vehicle (incase float is stuck), scan/clear again, add more fuel, rock again, scan/clear again, possibly try battery reset. If that fails, then further action is needed (either parts cannon, or some basic checking of wiring and powers/grounds).
pierrejoliat (01-01-2021)
Yes, I use these "LIDAR" sensors in alcohol tanks all the time, usually we just turn on the agitators to blend the alcohol and they start working again. {lack of turbulence in tank?}
Sometimes we end up changing them out, but a good cleaning seems to bring them back {at least the Allen-Bradley ones} The Siemens ones only work it seems on the darker alcohols. {Rum, Bourbon, Rye}
Received 1,756 Likes
2016 E350 Sport
Driving home from St.Louis to Dallas yesterday, Comand said I was on reserve fuel, and the range counted down from 60 to 30, where the range indicator stopped counting down (I hate that). I drove another 10-miles to Eufaula, OK, to the only station in sight, a Phillips 66.
Oddly, I found all the pumps offering only three grades of fuel: Diesel, Regular with ethanol and Regular without ethanol. To be clear, the station was not out of Mid-Grade or Premium… The (modern) pumps offered only Diesel, Regular with ethanol and Regular without ethanol. In 50+ years of driving, I had never seen this before. Ever.
Not wanting to fill the tank with Regular, I bought 2-gallons of Regular without ethanol, enough to get me down the road to a larger city. In McAlester, I bought 8 gallons of 91 octane Premium. When I left the station, the fuel gauge read ½ tank (355 miles remaining), more than enough to finish the 150-mile drive to home.
About 10 minutes later, at 70mph on the highway, the Comand screen notified, “Reserve fuel, do you want to search for fuel” or whatever. I look at the fuel gauge and it reads ¼ tank, and the Check Engine Light is on. I watch as the gauge goes to zero in about 30-seconds, no miles remaining.
I pulled over to shut off the engine and count to 30 before restarting. No joy. I popped the gas cap, thinking there might be some pressure in the tank. No joy. I checked for error messages in the display to find none. Just the CEL. So, I drove 150 miles home with no gas, according to the gauge.
Following are the code pages in Icarsoft…
And now, the (semi) good news…
This morning I refilled the tank to the brim with 93 octane premium from my regular station. 30-seconds after leaving the station, the needle jumped to “Full” on the gauge. The not-so good news is that the Check Engine Light remained on... Still no error messages in the dash display, and the scanner shows no codes for anything else.
While I was able to clear the codes in pic #2 &3, I could not clear the code in pic #1 (“Motor Electronics”) leaving the CEL on. I left the car locked in the garage for several hours, letting the car sleep. After that, I could finally erase the code. Back to normal, I think.
pierrejoliat (09-15-2021)
Received 3,777 Likes
MY'14 W212 M276 3.5NA @60kMi
low fuel... CEL: crazy R-SAM??
-Or
R-SAM just got mad and your fuel sender is A-1 perfect.
Is this a direct injection with 3-phase fuel pump or a classic 12v pump??
What caused left tank issue...: bad sender, bad GND reference, noisy 3-phase pump wiring, low float voltage from R-SAM??
This issue ended up snowballing into a CEL. Check if there are any related TSB to directly fix this.
pierrejoliat (09-16-2021)
2016 E350 Sport
it seems No3 DTC caused No1 to pop... the left fuel sender crashed the fuel tracking software in R-SAM that stopped handing to iCluster for display. Or R-SAM got nuts all by itself and sender is 100% perfect.
What caused left tank issue...: bad sender, bad GND, noisy 3-phase pump wiring, low voltage in R-SAM??
This issue ended rolling up in a bigger snowball: CEL. Check if there are any related TSB to directly fix this.
Received 4,617 Likes
Can it be that fuel level was so low, as such the float reached a potentionmeter level/region it never "rubbed" before and signal is then lost.
If it is a potentiometer based signal, areas we do not use/"rubbed" sometimes tends to have more oxidation and hence bad contact.
I see such thing happening on rotary/dial volumes control or un-used DC MCB on yachts. Simply never being used/"rubbed", they oxidize.
NOTE : Many yachts uses MCB as switch. Being 12V based, slight extra resistance drive component/s banana.
2016 E350 Sport
That said, I did run the tank low (as I had just one time before), so I suppose the system was not accustomed to that. My experience with electronics is that a failure displays instantly, while in this case, I was able to find gas, add 8 gallons (back to 1/2 tank, warnings gone) and resume my drive for several minutes before the gauge (slowly, not instantly) plummeted to zero.
I can't decide what to think about this, other than add some detailed input to this thread for reading by others who experience the same situation. Other than this, my car has been gremlin free for three years so far.
Fuel gauge showed little Less than 3/4 then went to 0
Hey Everyone,
need some help with my issue. I recently purchased a Mercedes e350 2020 model. I filled the fuel to full tank. The reading on my console showed little less than 3/4. After driving around for couple of hours and shutting down the car then starting back up the fuel tank read 0. After a day the check engine light pops up.
i took it to a service agent and he said its a cluster problem and reset the cluster and now again I have the same issue. I have not invested in a obd2 reader.
little bit history on the car, this car is an import in my country. This was imported from the states to UAE. This car had a passenger side damage. The cluster was converted from a semi digital to a full digital when I got the car. Can anyone guide me as to where the problem is before I start wasting my money with the service agent? At this time any suggestions would be great.
thank you
Chirag
thank you
Chirag
CaliBenzDriver (12-08-2023)
thank you for your response. Unfortunately I do not know who did the conversion since this car is from USA and it was I believe converted there and resold here in the UAE I might be the 2nd or 3rd owner of this.
pierrejoliat (12-09-2023)
Oh boy, you'll have to find someone really good with Mercedes and xentry to check for faults and reprogram the digital cluster, some 2020's came with them some did not, so I would think it's possible. But I'm guessing. might want to have the local dealer in Dubai check where it came from and past service history.
