Retrofit AMG Cluster.
Old 04-28-2022, 09:15 AM
Timo Schroeder's Avatar
Class S 500 M278
Gents - a good friend, inquires about the possibilities of retrofit an AMG instrument cluster in his 500 facelifted. I have read that there are two options, either a recoding of the current instrument cluster, or buying an original AMG Cluster and installing this. As I understand it, both options require an encoding of the car's mileage and other car data. Is it correct ? And what should be used for the coding of the "new" instrument cluster?
Old 04-28-2022, 12:30 PM
BOTUS's Avatar
S500
should be possible but not easy - plus the red line will be some 800rpm too high - the ignition switch and cluster are linked from an immobiliser perspective and getting the mileage to match up will be some fun
dependant upon age / cluster model its brain might have enough space to force on the AMG programming - but then u r stuck with nasty graphics around the speedo and a hideous cheap boot up logo
shame they couldn't just charge $100 to enable the other menu set some of which have useful elements
Timo Schroeder (04-28-2022)
Old 04-29-2022, 05:02 PM
doni01's Avatar
2013 S550 4MATIC
Yes doable. I had it done. Purchased a AMG cluster from the same year car (2013) and had someone do the coding. He is in New York. If interested shoot me a PM and I can give you his info. Look at the pics below...
The following 3 users liked this post by doni01:
FrankIUOE (05-01-2024), Timo Schroeder (04-30-2022), WHPH28 (04-29-2022)
Old 04-30-2022, 05:22 AM
Class S 500 M278
Hi. Thanks for your reply and nice photos, and no problems at all ? Good weekend.
Old 05-03-2022, 09:31 AM
doni01's Avatar
2013 S550 4MATIC
Not that I know BTW the glass was dirty on the pic because we just finished the install and you can see the fingerprints...
Timo Schroeder (05-03-2022)
Old 05-03-2022, 01:36 PM
BOTUS's Avatar
S500
is this from a strangled turbo model - the AMG one I have red lines at 7500rpm
Old 05-03-2022, 01:52 PM
doni01's Avatar
2013 S550 4MATIC
It came from a 2013 S63 US Model.
Old 05-01-2024, 07:05 PM
FrankIUOE's Avatar
06 w215 CL500
Programming info
Can you sen
Old 05-01-2024, 07:07 PM
FrankIUOE's Avatar
06 w215 CL500
Programming info
Originally Posted by FrankIUOE
Can you sen
can you send me info for place to program cluster in New Youk TIA
Old 05-02-2024, 04:03 PM
doni01's Avatar
2013 S550 4MATIC
Sent you a PM with the info.
Quick Reply: Retrofit AMG Cluster.
