M157 ticking/knocking source?
As of recent ive been chasing a tapping/knocking noise that has me confused and worried at the same time. So the noise isn't the normal upper ticking sound that we get. This noise seems to be coming from the lower right side and can be heard better through the wheel well. Also the sound is only there when the engine is hot. Also the noise increases with acceleration. I have No CEL or misfires. I have clean oil and filter with no evidence of metal. Of course worst case scenario is rod knock but im inclined to believe it might be something else.
What could this noise come from? Exhaust manifold bolt? Bad spark plugs?
I'm trying to narrow it down before I spend the money and send it to the mechanic or try and dump it.
Problem with investigating these type of issues is that no one even MB dealers can pick up unless engine is stripped. But that's in itself costly. Better do lifters and then save $$$ or just sell the car if the noise doesn't go away.
Not my car but it sounds the same.
https://youtube.com/shorts/WXRWXa_j0qI?feature=share
I have the same noise and have read many tales about it on other M157/M278 but none reported a fix except one W212 owner who found a faulty/leaky spark plug. Others just replace the engine or get rid of the car which I'm sure will fix any engine issue but it takes out the fun of chasing and fixing the root cause.
Also, I've listened to some "normal" sounding engines and this noise rhythm is there in varying degrees but often not as loud which makes me think it's been amplified by exhaust leak or something. Oh well, I hope to live to tell!
I bought the car in this state with full knowledge of the noise and the potential worst case scenario of engine rebuild/replacement. I welcome all thoughts and input about the problem, but please let's keep things on topic (comments like replace the engine, these M278/157 engines are junk, engine is worth more than the car so forget it, get a new ride, etc. are off topic and not helpful).
Observations
- Car runs fine otherwise. No malfunction/check engine light related to the problem.
- Noise is on bank #1 (the right side ) and the noise is present all the time except at >2000 RPM at idle.
- Noise gets slightly better when warmed up. I can barely hear it with windows up and at a stoplight when fully warmed up but it doesn't go away.
- It's worse under load/acceleration. It's completely gone (can't hear anything) when my foot is off the gas pedal while coasting or braking
- During gear shift under heavy acceleration, it seems to disappear momentarily during the shift transition
- At cruising speed (60 - 100 mph) when acceleration is light, noise is mostly gone
- Noise is most distinct at idle speed of 600 RPM. It's still present during a high idle (900 - 1000 RPM) on cold startup, but it seems to "settle in" with distinct taps when idle decreases to 600 RPM
- Noise frequency increases with engine RPM
- My noise frequency is at exactly 1/2 the engine RPM which seems to point to something on the upper end (see chart below)
- The noise coincides with cylinder #2 firing event. This cylinder also has the highest values for engine smoothness (up to 2).
- Compression is high on all cylinders (205 -230 psi). It's lowest on cylinder #2
- When I lubricate all the coil boots with dielectric grease, cylinder #2 spark plug boot seems hard to take off even after a short engine runtime
- I get white smoke from both tailpipes on cold startup which seems excessive and takes too long to clear up, but it does clear up when engine is fully warmed up
- Stethoscope analysis shows noise is distinct on the top side near cylinder 1, 2, upper timing cover, but also loud on the bottom when listening at oil pan
- I can hear the pulsating noise through the exhaust. Seems loudest in bank #1 tail pipe
- Engine consumes oil but I believe I have a leak around the turbo/manifold but it may also be burning some oil. I can smell the oil burning. I consider this an unrelated problem to address at the appropriate time
- Most of the cylinders on the right bank #1 have scoring (haven't inspected bank #2), but I think the scoring is a red herring. I believe the scoring is what makes most give up and replace/rebuild the engine or sell their car before getting to the bottom of this noise. I respect those decisions.
- When I do work under the valve cover (rockers, camshaft, etc.) and button things, noise seems to disappear the first several seconds after the engine start (a bit subjective so not certain).
- Monitored oil pressure and it's within factory spec with no odd behaviors (see chart below)
Mitigation Attempts so far that have made no change
- Engine oil flush with Liqui Moly and fresh oil with genuine filter, no change
- Remove oil filter and run engine to check. No change
- Tried heavier weight oil 15W-40. No change
- Replaced spark plugs, torqued to spec and ensured proper indexing
- Replaced all rockers and lifters on bank #1. No change
- Replaced camshaft and actuator on intake and exhaust on bank #1 with known good parts (my original didn't look worn or defective). No change.
- Replaced upper chain tensioner on bank #1 with known good one. No change
- Cylinder leak down test is over 94% on the cylinders including cylinder #2
- Smoke test on the combustion chambers was fine including cylinder #2
- In-cylinder/running compression test shows no obvious issues in the cylinder health including cylinder #2
- Swapped fuel injectors and coils around with no change. I actually ended up replacing cylinder #2 injector because it failed.
- Disabled combustion on cylinder #2 with no change
I know my engine has other problems (scoring, oil leak/burning, etc.) which I'll address, but I believe they're unrelated
I believe the problem is from cylinder #2 based on observations noted above. The things I haven't ruled out are valve guides, exhaust leak, and bottom end damage.
If I listen carefully to clips of other M278/M157 engine running, I can hear this cadence of noise. It varies from subtle background noise dominated by the injectors ticking and normal engine noises, to the same noise that but not as loud as mine. Please take a good listen to your engine for slow subtle tap tap tap noise. Knowing what components causes this rhythm may give a clue
This could very well be something in the bottom end (rod, bearing) but not ready to pull the engine just for inspection. When I pull the engine it will be on the way to a rebuild to address the cylinder scoring
I'm attaching some annotated diagnostic info.
Blue trace is tapping noise. Red tall trace is cylinder #1 ignition event, lower red traces are other cylinders firing events in the firing order. Note that noise RPM is 1/2 of engine RPM
Cranking compression test shows no apparent defect in cylinders and valves
Oil pressure tracking showing proper response of the variable-flow oil pressure pump
2012 ML 63
127xxx miles
m157
new timing chain, new magnets, cam position sensors
new spark plugs
bone stock. no tune. NOT p30 performance pack
ISSUE:
Burns about 1qt of LiquiMoly 5w40 every 750 miles
black dust like residue appears on the rear hatch every fill up
OBSERVATIONS AND STUDIES:
compression 145-160psi on all 8 cylinders
the spark plugs looked used but not wet or burned up
small spots of external oil residue but no dripping and no signs of serious leak
engine runs perfectly
no codes ever
engine sounds strong, pulls like a nuclear power battle cruiser
2012 ML 63
127xxx miles
m157
new spark plugs
ISSUE:
no codes ever
Your compression seems low but I guess it's OK if you have no codes/misfire and it's consistent across all cylinders. Did you measure with a dial gauge and on a hot or cold engine?
By the way, how did you log your data? This is one of the more lucid diagnoses I have seen on this forum.
Recently I completed a 3000-mile trip within a week. This rig cruises smoothly at 70 - 100mph for hours with no issues at all other than the noise as described before. It did consume 2 quarts of oil in the process which I believe is a combination of leaks and burning due to scored cylinder walls. I'm beginning to suspect this noise may be caused by exhaust leak at the manifold but I can't explain why that happens only under load (even the slighted feathering of the gas pedal causes the noise) but seemingly disappears when foot is off the gas during coasting regardless of engine RPM. Does the M278 disable combustion during coasting? I've also heard suggestions that this may be caused by the dual-mass flywheel which kind of make sense with the noise disappearing during shift transitions but it doesn't explain the RPM and cylinder event correlation.
I'm actually thinking about taking this in to MB dealership and share all my diagnostics with them to see if they'll have other thoughts/insights. I'm just concerned that they may give me the usual runaround that "your cylinders are scored, you need a new engine" or "we've got to take the engine apart and go from there." The noise is so distinct that I'd think MB dealership mechanics or their field engineers can recognize what is causing it having ruled out potential causes from my diagnostics so far. More suggestions/thoughts from this forum is welcome.
The half speed, right before #2 ignition just strikes me as significant. Could be an injector at that time as well but you had changed those as well.
Sorry I can't be of more help. I am still really impressed with your diagnostics.
