C63/C63S AMG
2019 glc 63 engine exactly the same as 2016 c63s engine?
Old 10-28-2022, 04:41 PM
AMG63s45's Avatar
C63s amg and CLA 45 amg
I am gonna put a 2019 glc 63 motor in my 2016 c63s is everything exactly the same like the block, heads and internals? Including the tuning?
Old 10-28-2022, 04:51 PM
C43 Fun Haver's Avatar
2015 ML63
I Mean if you have the vin # from the car its coming out and and the car it's going into.. ill tell you if the heads/block some internals.. but i feel like there is plenty different to make it not work.. but i do like being wrong in some things
Old 10-28-2022, 05:22 PM
mercedesmax's Avatar
2015 CLS 550 2015 ML 400 Previous 2020 GLB 250 2019 A 220 2005 ML 350 1989 300 E 2001 SL 500
Is it an S motor?
If not, there are quite a few internal differences between the 63 and 63S motors.
chassis (10-28-2022)
Old 10-28-2022, 05:30 PM
chassis's Avatar
Received 3,983 Likes on 3,130 Posts
2017 GLE350 4MATIC
Originally Posted by mercedesmax
Is it an S motor?
Is there more to this?
Old 10-28-2022, 05:37 PM
AMG63s45's Avatar
@mercedesmax no it is not an s motor. What are the internal differences between the s and non s?
Old 10-28-2022, 06:20 PM
According to our AMG rep the block is the same. Pistons, connecting rods, turbos and software tuning are different. Can't remember if the heads are.
Also, the S motor has the dynamic motor mounts. Fluid filled mounts that can stiffen up to increase chassis rigidity
Old 10-28-2022, 06:50 PM
AMG63s45's Avatar
@C43 Fun Haver here is the glc 63 vin: WDC0G8JB9KF488367 and here is my c63s vin: 55SWF8HB0GU099233
Old 10-29-2022, 09:14 AM
2015 ML63
Intakes manifolds are different
exhaust manifolds are the same
block is different
Turbos are the same
heads are different
same crankshaft
different crank pulleys though..
different fly wheel
intake and exhaust camshafts are the same
intake/exhaust valves are the same
pistons are different
same connecting rod
  1. WDC0G8JB9KF488367
  2. C253_FX
  3. Engine: 1779806006497
  1. 55SWF8HB0GU099233
  2. C205_FW
  3. Engine: 1779806000533
Oil pans are different also
Looking at the turbos more. They are the same between the models but the oil feed line for the turbos are different haha
motor mounts are different as-well like someone else stated
The following 4 users liked this post by C43 Fun Haver:
chassis (10-29-2022), George_1992 (10-30-2022), Jimmy_c63s (10-30-2022), Tobby (10-29-2022)
Old 10-29-2022, 12:55 PM
chassis's Avatar
2017 GLE350 4MATIC
block is different
Turbos are the same
heads are different
same crankshaft
different fly wheel
same connecting rod
  2. C253_FX
  2. C205_FW
What are the differences between the two engine blocks?
Old 10-29-2022, 01:40 PM
2015 ML63
I'm sure with some more digging I may be able to find that answer but maybe not.. it is probably something very small with either cooling passages in the block.
I see the option code for the glc engine also has F093 which you can read the description for that code. But the vehicle needs to have one of those 2 codes to apply with that. so F253 or F093.
The C class is only listed for one option code which is the model year/chassis
Old 10-30-2022, 09:11 PM
George_1992's Avatar
C63 S Coupe
Good info from C43 Fun Haver
Nice info you're posting and have access to. What program are you using? I need that
Doesn't look like WIS or EPC?
George
Old 10-31-2022, 10:38 AM
2015 ML63
Yeah this is the XHPI with the Xentry Portal, Im a parts advisor so i have my own D7 Login for it. I tried asking my foreman if he knew what the differences could be, he wasn't sure really. He said they could be the same but Mercedes may just want two different numbers for the models
Quick Reply: 2019 glc 63 engine exactly the same as 2016 c63s engine?
