2009 e550 4Matic front end problems
When I drive bout 30mph or try to pedal to the metal the gas the front of my car wheels wobble like something’s lose I changed the passenger side axle upper control arm inner tie rod and outter tie rod I don’t knw wat it can be I knw I need alignment car pulls to the left can a bad air shock make the wheels wobble if it’s worn
Received 4,417 Likes
'71 Pinto
How about axle...
'71 Pinto
Well move on to steering knuckle/lower control arm, torsion bar links and dare I say wheels.
'71 Pinto
Yes, wheel/tire, best way to rule out is have them road force balanced: locate a balancer https://www.hunter.com/wheel-balance...d-force-elite/
'71 Pinto
You don't have shocks equipped with Airmatic struts stretch to think these are causing tire 'wobbling'.
'99 CLK/05 E500 WAG
Check your lugs...I recently had my tire balanced/ rotation and they had the lug off just a but which was making a funny noise on passanger side front. I didnt even make it out of parking lot when i flag tech down and had them check and redo all the corners. All was gud since. Just my humble opinion
R,
2Merks
R,
2Merks
Johnnyb46 (02-05-2023)
R,
2Merks
R,
2Merks
2MERKS (02-06-2023)
