M276.8** 3.0 Turbo on W212 chassis & RWD - Oil Pan Removal Clearance
Received 4,098 Likes
2014 - W212 - E400 ( M276.820, 3 liter Turbo) RWD not Hybrid
Gents,
Something to share, just in case you guys are as **** as I am on preventive maintenance, the dangerous & critical o-ring at oil pan baffle,
discussed here : https://mbworld.org/forums/e-class-w...brication.html
Note my car is RWD and not 4-matic which is much more of a nightmare I am sure.
Also my oil pan is fatter/bigger at its rear, where it mated to tranny bell housing.
This is my oil pan design.
Clearance if based on forward part of oil pan needed to be lowered and then slide out towards car rear, I am short of 6CM.
The 9 CM hump is for oil pump.
I am wondering if it will safe to lift engine to +6 CM ( 2 of engine mounts removed ) and then loosening front subframe to drop it by -2CM like when others are doing engine mounts replacement
by way of dropping a bit the front subframe. So I have 8CM working space to slide out engine oil pan. Hopefully enough.
I estimated the angular twist will happen to my tranny mount and at the propeller shaft center bearing, but the degree is small.
ABOVE : Angle at tranny mount. BELOW : I can also loosen the U plate holding the tranny mount and drop it by -1 CM.
Angle at propeller shaft center bearing.
I can adjust/align the propeller shaft center bearing so the yoke will take the upward twist.
Perhaps the 2 bolts of center bearing holder ( item 7 ) I drop by 1 CM.
Dimensional reference
DAMN !!!! Tomorrow I will need to measure tranny tunnel clearance on car body to tranny casing and engine bell housing.
Can it take 6 CM of engine height uprising ?
Any useful tips will be appreciated.
