GL Class (X166) 2013-2015 after facelift became GLS (X166)
2014 GL 450, $6,767.02 Repair Bill
Old 06-26-2024, 05:25 PM
NYGL450's Avatar
2014 GL450
Hey All,
Long time lurker, first time poster. Posting because I am in a dilemma. Bought a pre-owned 2014 Mercedes-Benz GL 450 in 2018, with all the premium bells and whistles in options.
Drove like a dream until November '23. Engine started making knocking sounds and would still make a noise after being turned off for a good 5 mins.
Got it checked out by a Mercedes-Benz technician and he said it was the camshaft and camshaft gears. Given the car has 110,500 miles on it, I did not know what to do and left it on the driveway.
Now, I got a diagnostic done by a Mechanic Shop specializing in German Cars, in NY.
They just got back to me with a $6,767.02 estimate, which does not include the potential for finding something more wrong with the camshaft once they further unassembled it (attachment).
Is this a normal occurrence with this model or did I not do something preventative? Given the KBB, what you all recommend as the best course go action?
Thank You, I really appreciate all the help!
Old 06-26-2024, 08:12 PM
Tsumi's Avatar
2006 R500
2014 GL is X166, not X164. Completely different engines.
NYGL450 (07-02-2024)
Old 06-26-2024, 08:27 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
166 motor
I have not heard a lot of good things about the Turbo motors and resell prices reflect that. I personally prefer a non turbo 550 motor.
Should move this to the X-166 forum. If you are mechanically inclined you might want to take on the job and save the $4400 in labor or at least find a hood Indy shop and get some quotes. good luck and follow the link below and you will find there are many losing engines after perfect maintenance history .
https://mbworld.org/forums/gl-class-x166/815733-2014-gl-450-blown-engine.html
Old 06-26-2024, 08:29 PM
Sallad's Avatar
08 GL320 CDI
Do you mean the engine will "stumble" and "chug" as if still trying to run AFTER you turn the key off?
That sounds like Dieseling or engine run-on. Google that and see if that sounds like yours. If so, I doubt a timing chain adjuster repair would fix that.
Old 06-27-2024, 08:59 AM
eric_in_sd's Avatar
2007 GL450
@MJ50 belongs in x166 forum
The following 2 users liked this post by eric_in_sd:
MJ50 (06-27-2024), NYGL450 (07-02-2024)
Old 06-27-2024, 10:22 AM
Elbeau's Avatar
Mercedes gl450
Yeah. I was thinking the same thing. Unless he's talking about run-on after shut-off, I don't see how non-moving mechanical parts can make noise. I don't know if that quote was made based on the dealer's prior "diagnosis" but I suspect it must have been.
Old 06-27-2024, 02:53 PM
eric_in_sd's Avatar
2007 GL450
Something truly surreal is going on. How do you have dieseling in a fuel-injected engine?
I'd bet that price quote is a work of fiction. The mechanic was probably thinking, no way will the customer take me up on this, so I'll just make something up.
Old 06-27-2024, 02:57 PM
Elbeau's Avatar
Mercedes gl450
Good point unless the ignition system keeps running somehow.
Old 06-27-2024, 07:24 PM
Max Blast's Avatar
Now just one GL450 with EORP.
I’d recommend the x166 forum chew on this one.
@admin
MJ50 (06-27-2024)
Old 06-27-2024, 08:13 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to X166 forum...
Old 06-28-2024, 11:00 AM
kajtek1's Avatar
Received 1,736 Likes on 1,384 Posts
1922 Ford Model T / no OBD
Noise for 5 minutes after shut down most likely is aux water pump evening "hot spots" on the engine. Can you give better description?
The attached estimate is for timing rebuild. MB engines don't just wear out at 110 kmiles, so I would definitely do 2nd opinion.
Old 06-29-2024, 10:28 AM
silvergl's Avatar
GL 450
Interesting
I am very interested in this thread. Having been through an engine replacement, diagnosis that was one of the earliest on this forum. Running after the engine is shut off is crazy. Maybe it is just the water pump or fan trying to cool the engine. Get a mechanics stethoscope for $10 and pinpoint where the noise is coming from that is the first thing. I agree with the other comment about it was a throw away bid bc he did not want to mess with it. I would be it is an engine out repair, or atleast the front clip comes off. You cannot even do VCGs with out pulling the engine. I would also scope the cylinders, the rattling could be related to scored cylinders, I would probably expect this with the mileage. It sounds like you may want to pay someone to scope the engine, but you could do the stethoscope yourself. A few hundred bucks and you have a more informed perspective
Where are you located? I am sure someone could point you towards a good indy.
Old 07-02-2024, 10:47 AM
350gunner's Avatar
GL350
I would love to find a good indy in the Bronx/Westchester area, if anyone knows a shop. My dealer has been spotty when I use them for service.
Old 07-02-2024, 11:23 AM
silvergl's Avatar
GL 450
That west chester dealer is garbage, I had my car there once, jerked me around forever.
Not too far away, and in my opinion worth the drive, where I had my engine work done, in Hightstown NJ is City Auto Center. Tony Sandu is legit and trustworthy. Anything on any of my cars I cannot do myself goes to him.
City Auto Center
180 Mercer St #164, Hightstown, NJ 08520
Open ⋅ Closes 5:30 PM
cityautocenter.com
cityautocenter.com
(609) 448-9800
Old 07-02-2024, 09:35 PM
NYGL450's Avatar
2014 GL450
Apologies for posting it in the incorrect forum. I am still on the fence. I will get it back from the Mechanic tomorrow and record the Start, Drive, and Stop to share with you all. Maybe it will offer more clarity. But just an intuition that it sounds steep.
Old 07-09-2024, 12:59 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Noise after turn off is an auxiliary water pump you can buy for change aftermarket on eBay located under driver side fender liner. The rest is a rip off unless properly diagnosed.
I have M278 with 160k miles still riding on original timing chain and camshaft sprockets.
Quick Reply: 2014 GL 450, $6,767.02 Repair Bill
