I want to buy a US salvage 2024 E350, but got a little confused regarding the audio system.
Both cars have a Burmester silver-plated speakers in the front doors.
However, for the back seat, only one of the two cars got a Burmester silver-plated speakers in the doors, while the other got black-plated speakers.
It's only a guess, but I would think the one with the black speaker grills in the rear does not have the Burmester sound system. If the car does not have it all door speaker grills are black, with it all are the silver ones.
It's weird man cause the front doors do have the burmester grills while the rear doors don't.
Is it possible that the previous owner put on imitation Burmester speaker grills on the front? They are readily available from AliExpress.
I highly doubt it. Why would they replace the front grills but not the back? I also have seen 4 other 2024 E classes with the same grill design, burmester front and black in back.
I want to buy a US salvage 2024 E350, but got a littlconfused regarding the audio system.
Can someone explain to me the difference?
The red circle in the above picture shows the lever opening the car door, not the speaker. It is too high up and too rearward. The rear door speaker grille is lower and more forward near the front of the silver door arm rest area. I am sure of that.
You are right. I put the circle a little above, but below, part of the grill should be be visible. Right here it is showing but no too visible due to the picrure quality and door color.
As Ewok said, you are looking at the door handle. The silver speaker grille is obscured by the seat and cannot be seen in that picture. My guess is they are the proper silver grille for the rear. I'm assuming you haven't seen these cars in person so you should probably go do that. Or, at least have the sales rep take some additional pictures to ease your mind.
I'm sure it is black. Later I will post pictures of other cars having silver grills in front and black in the back.
