2017 E300- Just notice turn light makes no clicking noise & Blind spot does not beep!
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Today my car no longer makes a clicking noise when I put on the turning signal but works!?
and blind spot works, but no longer makes a beeping sound when someone is in my blind spot!?
They must be related?
NO other problems, thanks in advance!![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Received 2,689 Likes
https://mbworld.org/forums/e-class-w...ml#post8991653
trigital (Today)
This issue popped up on the C-Class as well: https://mbworld.org/forums/c450-c43-...des-chime.html
DO you know which fuse and fuse box, there are 4 fuse box's on my 2017 e300 w213
and what is key chime?
thanks!!! :-)
thanks!!! :-)
It must be the speaker, checked all the fuses in all 4 locations!
also my door chime and left key in car chime is gone also!
so you have a pic of where that speaker is? :-)
I don't have a W213 around me so I can't go and look for you. There is a specific name for this speaker so searching online might not find it but you might be able to see it if you look for it.
Received 1,764 Likes
There is a good chance that a malfunctioning speaker will throw a DTC. Scan your car.
That said, OP's turn signal also doesn't click so it is certainly this being the culprit, it wouldn't be a disabled setting.
As for the warning sound, go here https://cimg7.ibsrv.net/gimg/www.mbw...dfcf03c01a.png
Good for you of finding it to illustrate unless that is an image you took yourself, I have no chance finding such image online as I remember MB calls it some other name.
anymore clues?? :-(
here's a photo I took....
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x901/20240908_092730_954d1ee43f9304269f35fed8811363537084c708.jpg)
