Cooling System - something is up
Few weeks ago I got a Check Coolant light....it was low, coolant was on the floor. So, play around, get a whole new tank (the other one was old). Same issue. Well, get a new cap. Seemed to have fixed the issue.
Today "check coolant" is on (starting the car). Signs of coolant on the tank, and under the engine cover......what y'all think I should check next?
Received 2,180 Likes
How's the lines to the reservoir tank? Also some other ideas in the threads below from the sticky, one guy used UV dye to track the leak
https://mbworld.org/forums/w212-amg/...ml#post7800246
https://mbworld.org/forums/w212-amg/...ml#post7801476
https://mbworld.org/forums/w212-amg/...ml#post8648289
https://mbworld.org/forums/w212-amg/...ml#post8670175
https://mbworld.org/forums/w212-amg/...ml#post8717462
CaliBenzDriver (Today)
Received 1,892 Likes
Is that the one for the turbo intercooler? There are two coolant circuits and they are separate. One is for the engine and one is for the turbo.
The car is in right now getting pressure tested. This, days after the other thread about replacing the pump and all plastic hoses on the cooling system...I am due.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
