New owner of 2016 E63s Wagon and we have a problem with vibrations
Old Mar 21, 2025 | 12:25 AM
T.M.Y's Avatar
Hi to all…
Long story short. I purchased beautiful and clean 2016 E63s Wagon with 56k miles, black with designo black/orange interior. Car is super clean, no accidents etc…. Mint
Before purchase, took it on a test drive, everything was fine… didn’t drive more that 50 mph probably (small “residential” streets and cop’s everywhere). After purchasing, on the way home, on the highway, speeds 55mph slight vibrations coming from the back of the car. Faster you go, bigger vibrations. At 90mph it’s getting really uncomfortable.
i didn’t contact dealer, i will not waist my time fighting with them over this issue, since it’s a used car with no warranty. Paperwork signed, nothing else to discuss.
i took it to my good friend mechanic shop that usually works on german cars.
he change engine oil, trans fluid and both diffs fluid. No metal shavings etc. he check all suspension components, driveline, engine and transmission mounts, all good. Only thing that he found was little oil around one cam magnet (but harness is dry).
tires are pretty much new, made 24th week of 2024. Wheels are in great condition, no visible damage or even curb rash.
Does anyone had similar issues?
It’s hard for me to believe that problem is in unbalanced wheels because usually vibration going away with higher speeds, in my case, they are way worst….
any help is greatly appreciated….
Old Mar 21, 2025 | 01:43 AM
PeterUbers's Avatar
99% of the time it's the wheels/tires; rebalance them and check their balance without the tires, check for bends in the rims with the tires off.
to be clear - your German car mechanic checked the wheels and re balanced them, yes?
I've seen people struggle with this kind of issue then take it to a 3rd guy to balance the current or new tires (after the first two guys failed or gave up) and boom - smooth ride. Some guys aren't as good at balancing tires as others; also these cars wear the inside of the tires aggressively and the tires can lose balance over time
less likely the rotors are causing a balance issue
$0.02
Old Mar 21, 2025 | 05:42 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
I agree that it sounds like wheels and tires since you do not mention that they were put on a balance machine.
You also mentioned that he changed the fluid in the front diff? That’s usually a complicated procedure in this vehicle and not just a quick drain and fill with two bolts. It would be surprising to me that he would do this before checking the roundness of the wheels or balance of the tires.
I can understand thinking that out of balanced tires would get smoother the faster they spin, but that’s not really the case.
Are you sure this friend is a “good” mechanic?
Old Mar 21, 2025 | 06:47 AM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
If the car has spacers especially on the front, remove them and the problem solved. Trust me---been there done that- Welcome to the long roof club
Old Mar 21, 2025 | 09:04 AM
JettaRed's Avatar
Veteran: Army
Everyone has stated the likely culprit. As Balti stated, the front diff is not an "easy" service. You also have not said you scanned for codes -- not all problems show up on the dash.
With that low mileage, the car is practically new. However, I would have the mechanic check the driveshaft and U-joints. It's unlikely you have an out of balance or bent drive shaft, but when a U-joint goes, it shakes the car to pieces.
Old Mar 21, 2025 | 09:29 AM
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
You did not specify but a "road force" balancing machine can make a difference as well.
Old Mar 21, 2025 | 09:39 AM
PeterUbers's Avatar
agree - I hope there were two unrelated separate line items:
1. Let's Do some routine maintenance and a PPI (post purchase inspection) on my new/used car - so the fluids are changed, engine inspected yada yada
2. And btw, I have this vibration at higher speed - so now the wheels are checked while car is on a lift (not put on a balancer), mounts inspected, can't find issue
was this car due for these maintenance items? The seller hadn't done them? Was there a PPI (pre purchase inspection)
you mentioned some "oil at the magnet" - like leaking from the magnet down the engine or in the harness? An important distinction - as in - did the magnet get replaced? Did the harness get inspected for oil creep?
T.M.Y's Avatar
Thanks to all for fast response.
I didn’t check tires for balance so that’s first step I guess.
Magnificent New Mercedes-Maybach S-Class Revealed: 12 Things to Know
Old Mar 21, 2025 | 09:40 AM
PeterUbers's Avatar
question is - why didn't the mechanic do this?
Old Mar 21, 2025 | 11:31 AM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Keep us updated OP
Old Mar 22, 2025 | 04:03 AM
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
Just did the front diff. Super easy. Drain and refill 700ml of new oil through the drain plug. Add 65ml for spillage, done.
Old Mar 22, 2025 | 08:34 AM
Baltistyle's Avatar
While I agree it can be done this way, that is not the way that it is asked to be done by Mercedes. To me, the trick to make it easy, by going up through the drain plug would be done by a mechanic that would know to check the wheels first… so do we really think it’s likely this mechanic knew the shortcut, or knew how to do it right? An easy normal diff with a fill and a drain plug I can imagine being done right, but not this one in this circumstance. Didn’t the test ride and scanning of codes before doing any work with the mechanic point in the direction to start? It didn’t sound like either of those were done by this friend before starting work.
A good ppi from a friend should consist of test drive, scan codes, under body mech inspection, engine bay and sensor inspection, boroscoping cylinders, compression or leak down test, then fluids, balancing and alignment.
Old Mar 22, 2025 | 09:37 AM
JettaRed's Avatar
Veteran: Army
Draining is easy. The refill should have required disconnecting the front axle shaft at the differential/transmission case. Both my cars are RWD, so I haven't had the pleasure of removing the front axle shaft, but that sounds more complicated than "easy". Also, fill capacity is 550ml. If your mechanic added 765ml of fluid, that might be too much.
Old Mar 22, 2025 | 09:55 AM
BDC90's Avatar
Actually if You have the fitting for filling the transmission pan, You can use it to fill the front diff. Add a little extra, plug the fill hose then as you remove the fitting quickly put Your thumb over hole. Then just as quickly move thumb and screw in plug. I hardly lost any fluid during thumb swaps at all.
Old Mar 22, 2025 | 10:03 AM
JettaRed's Avatar
Veteran: Army
Good to know. That seems similar to changing the Haldex coupler fluid on certain Audi AWD systems, only there is a required change interval on those devices. (Who the hell designs these things and forget to include how to maintain them?)
Old Mar 22, 2025 | 12:37 PM
I.T. Guy's Avatar
2023 E63S Wagon
If it's not the wheels check the propeller shaft and hanger bearing next
I had two go on my W212
Old Mar 22, 2025 | 12:39 PM
PeterUbers's Avatar
good call
https://mbworld.org/forums/w212-amg/...als-speed.html
Old Mar 22, 2025 | 02:34 PM
Baltistyle's Avatar
yep, that’s the trick. (My point was only that a std mechanic does not know this) I’ve wondered if a fumoto type valve could be used on some of the systems. Fill them up, close valve and done.
Old Aug 17, 2025 | 02:10 PM
Chappy's Avatar
AMG
Was the issue resolved? I had a similar issue on my ‘14 wagon and was resolved with new motor mounts and transmission mount.
Slideshow: Mercedes-Maybach has refreshed the S-Class with new lighting signatures, AI-driven software, and even more elaborate rear-seat luxury.
By Verdad Gallardo | 2026-03-25 18:01:51
