Sponsored by: CARiD
Need advice on spark plug replacement
Old Mar 8, 2026 | 09:04 PM
edes300's Avatar
I am looking for some guidance on spark plug replacement for my 2014 E350 with the flex fuel option, although I have never used E85 in this car. I bought the Bosch plugs from FCP euro for the models with Flex fuel. I starting tearing into the project but I stopped when I looked at the first coil pack it was solid black plastic. My understanding is that the flex fuel cars also use a different coil pack which is black on top and white or gray on the bottom (at least on FCP's website). I put everything back together and wanted to get some more info. This is my son's car so I didn't want to start a project I couldn't finish right away. I bought the car used so I don't know if the plugs or coil packs were ever changed before. The car has about 62,000 miles on it. Any help would be greatly appreciated. Thanks in advance.
Old Mar 8, 2026 | 09:28 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
you definitely want to use parts for a flex-fuel car regardless of not using E-85, the CPU is programmed differently to run with the flex-fuel parts. I believe the actual combustion sequence is similar to the Euro version, I will check my Flex-fuel car for color specific variation in the coil packs Against my non-flex fuel car tomorrow morning and report back. they are definitely different part numbers. My daughter has it until luchtime tomorrow as her car is at the dealer
Old Mar 8, 2026 | 09:46 PM
Arrie's Avatar
2010 E550, 273 Engine: 2012 S550, 278 Engine
Why change plugs or coil packs with that low mileage?
Old Mar 8, 2026 | 10:24 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Multi-sparks GDI plugs are rated 50k.Mi only... they come out looking brand new
I think the E85 engines use premium NGK plugs with flat top instead of the usual stuby pin.
Just replace the [plugs + boots]
QA-inspect each spark-plug before installing
Keep your coils.
Old Mar 9, 2026 | 08:44 AM
edes300's Avatar
thanks I appreciate it if you can do that for me.
Old Mar 9, 2026 | 12:42 PM
Mine are all black just like the non-flex fuel ones, but they are original parts at 108k miles, I did change the plugs at 60k, as Cali says they are not Bosch, they are NGK's I bought at Mercedes to insure correct positioning. Maybe the OEM manufacturer just changed the color to differentiate them from OE, or its a revised part.
Old Mar 9, 2026 | 12:46 PM
Keep your coils.
As always Cali, spot on
Old Mar 9, 2026 | 03:07 PM
edes300's Avatar
thanks for checking that for me. Greatly appreciated
Old Mar 11, 2026 | 01:12 PM
QA PLUG MATTERS
@edes300 can you post close-up pictures of all 6 plugs electrodes: Ground + Tip ?
> LET'S LOOK AT :
  • The ground strap for un-wanted burrs
  • The ground strap sharp/round edges
  • The electrode gap exact measurement
  • The indexing from the thread to strap
The plugs are the most essential components for basic performance from excellent combustion.
Lean mixtures sparks are extremely difficult to produce.
> WORSENING MISFIRES:
We are facing a vicious cycle we best must stay ahead of.
Weak sparks cause misfires that in response call for lean mixtures that cause worsening misfires that earn less fuel....
That means failed ignition misfires are a very slippery slop !!
> AVOIDING MISFIRES:
The bleeding edge of igniting lean E85 mixtures is both an art & a science, it's extreme.
Misfires are easily caused by more than poor sparks alone.
Each cause has its own fix.
Let's focus on the sparkplugs while we have them in hand.
-- In the ball park of sparkplugs I under gap my electrodes at 0.7mm (+/- 0.05mm... 0.65 to 0.75)
-- Wider gaps do not produce longer sparks... quite the opposite regardless of high voltage!!
-- The spark exact timing benefit being precise. Mixture ignition must be always predictable with minimum randomness.
-- Aging hot plugs gap tend to widen with bent steel memory effect plus precious metal wear.
-- The shape of the tiny needle tip vs. more stubby platinums is used to strike across a single identical path.
Meaning that path better be guaranteed to fire up.
Take the time to assess your electrodes to perform best despite hellicious conditions.
### work over a table to prevent cracking your ceramic sparkplugs from a drop on the floor.
Don't trust dropped plugs reliability - Replace or install as No1.
Old Mar 11, 2026 | 08:48 PM
edes300's Avatar
Here are some pics of one of the new plugs. They all look the same to me I bought them from FCP Euro.
Old Mar 11, 2026 | 10:46 PM
This is a sample of one plug from the new set.
You want to review each plug individually.
inspect for burr protruding from ground strap... file it round.
inspect for burr protruding from ground strap... file it smooth round (not the firing surfaces).
center electrode: not to thin + not too stubby
This looks more like a dual-platinum rather than dual-Iridium needle
Old Mar 12, 2026 | 08:28 AM
Those are not NGK 96427's, I'll assume those Bosch plugs are for a non flex-fuel car
Old Mar 12, 2026 | 09:06 AM
Stock NGK (Bosch??)
As Pierre hinted Bosch in this flex-fuel engine are not usual vs. stock NGK parts.
Now triple-check the plug reference sold by retailer.
Search what MB references for your VIN
Search your preferred supplier for that MB P/N.
Caribbean waters look alike Jacuzzi
Mind your parts cross-reference is valid.
When in doubt: GENUINE parts are the most compatible for your application.
Thread plugs by hand until near bottomed down, then torque to specs.
Old Mar 12, 2026 | 11:28 AM
Old Mar 12, 2026 | 07:57 PM
C280 Sport's Avatar
MB’s of all kinds.
On every MB with the M276 engine I have ever had I changed the plugs and coil packs out at or a little over 50k miles FCP sells an ignition kit by BOSCH for like $400. Well worth it.
Old Mar 12, 2026 | 10:26 PM
Arrie's Avatar
I often wonder what people do with their cars. I have a 2010 E550 with almost 190000 miles on it. I have changed oil every 5000 miles and it runs like new.
I have changed the spark plugs only once at 100000 miles. The coil packs are still the originals and I’m not planning to change them before the first one goes out.
Old Mar 12, 2026 | 11:39 PM
pros and cons
You're running a M273 V8 Non-turbo multi port. It's a gentle giant with both power and torque.
Your engine type does not buildup super-heat like later GDI Twin turbo V8 setup with limited oil pressure or "hot-V8" with exhaust turbines nested in the center of the V.
Less accumulated heat helps cooling parts and seals last long. Injectors and Coils do not burn up to see a normal lifespan.
GDI engines inject gasoline during compression strokes and fire multiple sparks in piston top cavity. These gas engines can sound very much like diesel wip.
> Mixed Pros & Cons :
One of the M273 draw back is the single long timing chain with its hard-spring tensioner.
M278 has four chains with low stress hydraulic tensioners that rattle when conditions are present.
The result is a lot of good mixed with little bit of bad.
Old Jun 3, 2026 | 08:39 PM
edes300's Avatar
I'm reviving my old thread on this issue.
I finally got around to going to my MB dealer and ask them about the plugs. They put my VIN in the computer and gave me part number 004-159-81-03 at a cost of 53 dollars EACH. I decided to do my own checking on this and when I look it up that seems to be for the non flex fuel version and its a lug made by Bosch. From what I can tell I should be buying NGK part number SILZKFR8D-7S. Now I'm not sure what to do, any help would be appreciated. Thanks in advance.
Old Jun 3, 2026 | 09:49 PM
hands on check
You are getting conflicting information regarding your spark plug type by VIN from your dealer.
The difference between flexfuel NGK plug vs. standard Bosch type is the head connector.
  • Flexfuel has a flat top connector
  • Non-flexfuel plug use the standard pin style connector
Both setup style use different coils and different boots ie. not interchangeable.
(*** ) Have a look physically by removing an easy accessed plug: flat top ??
You can order both types and return parts you don't need - In any case you will need new matching BOOTS and PLUGS.
(*** ) more simple check...
remove coil and boot to see flat top connector - Leave plug in place, no need to remove plug to see its top head connector.
Old Jun 4, 2026 | 01:26 AM
johnfranciscog's Avatar
2011 E350 4MATIC Wagon
um because the service manual says to.
Old Jun 4, 2026 | 04:42 AM
Post correlation of damages
In your experience of Sce writer, what's the correlation between burnt coils AND burnt injectors ??
Can burnt ignition coils be used to predict damages from burnt injector coils ??
If so... is this an incentive to preserve the engine from the extreme heat stored in dry pistons ??
### MB Vito van - HK "New-territories" district: Hot tropical summer!!
Attached Thumbnails Need advice on spark plug replacement-screenshot_20260604_164043_gallery.jpg
