GLC Class (X254) Produced 2023+
GLC Audio/Burmester Sound Profile resetting
Old May 4, 2026 | 05:45 PM
spyked's Avatar
2026 GLC300 4Matic (X254)
Hi. I have a 2026 and I have a 3D sound profile set up. In the section where it has the 4 quadrants and you slide it around to your preference, that part often resets to baseline/middle. Sometimes it goes days and works great at each start up, then other times it forgets my setting/resets 2x a day. Anyone else have that issue?
I'm talking about where you go through the questionnaire and set the sounds the way you like and at the last part you can fine-tune it using the quadrant area. That resets to factory settings. Thanks. My SW appears up to date and I did a OTA update just last week for something else (whatever it needed, it was screen-related I think).
Old May 4, 2026 | 11:14 PM
mbscapd's Avatar
2026 GLC300 C
I don't have anything useful to add, but may be user profiles might have something to do with it? Are you using the same key fob, or user profile etc? I am the only driver on ours so far so I haven't really messed with user profiles yet other pairing alone keyfob to me.
Old May 5, 2026 | 05:49 PM
spyked's Avatar
Same key, same user profile. And actually trying experiment with "guest" or non-signed in user too. Works the same. It stays in memory sometimes, then other times not. Weird.
Old Jun 16, 2026 | 06:51 PM
55wagon's Avatar
05 E55t, 07 R63, 04 Mini R53 (SOLD):01 s4 avant st3, 06 q7
I gave up on that also.. it changes everytime I get out and in again.
Old Jun 17, 2026 | 05:23 AM
W205C43PFL's Avatar
OP you said your software is up-to-date can you tell us the specific version you have?
Old Jun 17, 2026 | 07:50 PM
spyked's Avatar
Sure, my car is running E333.8-58
Old Jun 17, 2026 | 08:06 PM
W205C43PFL's Avatar
OP, thanks for letting me know, I want to let you know there is a newer version out but not sure if it fixes this reset problem though, E354.2-4221 some got it some didn't. https://mbworld.org/forums/glc-class...er-screen.html
Old Jun 17, 2026 | 08:23 PM
spyked's Avatar
Thanks. Luckily I've never had any screen reboot issues. In fact, on April 27 I got an OTA update notice on my phone for "Software update for the central display" so I did that. Update process was easy, but I didn't check what SW version I was running before the update.
Old Jun 18, 2026 | 08:07 AM
W205C43PFL's Avatar
You're welcome, as for the reset issue not sure the latest software addresses it as well.
