What color should I paint my calipers?
Should I paint the stock rear calipers to match? I can't decide if I should paint those black or color match the front.
This is a real photo of my car. I used photoshop to compare colors.
If you had a custom color car like light blue then i'd say go with the wacky color calipers, you will notice the cars paint 1st then calipers second. If that makes sense.
Paint the stone guards silver while you are at it (just mask off, you only need to paint what shows)
Paint the wheel bolts (drill 5 holes in a piece of timber to stand them up in and spray them all together)
Paint the brake rotor hubs silver which usually look rusted (but don't paint where the rotor mates to the wheel, just clean that up)
Take the wheels off the car one at a time and thoroughly clean the inside behind the spokes with degreaser, and then paint the inside silver to match the outside (use a toothbrush to get the grime out of the lettering)
Fit some metal dust caps for the tyre valves, silver.
Buy some new centre caps with the tri star and Mercedes logo (you can get them online cheap)
There was thread on here not too long ago where the person had installed metal caps and could not get them off due to corrosion.
with white body and red calipers... so mismatched colors.
### A45 as spotted in Guilin CN
