SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Motor Oil
Old May 21, 2006 | 06:56 PM
HLG600's Avatar
2009 SL63 AMG
Motor Oil
Anyone run Castrol Syntec or GTX in their cars?
Old May 21, 2006 | 07:30 PM
l5foye's Avatar
This is not a response to your question but I have been told that Castrol no longer make oil - it is just a marketing name. Shell and Mobil supply Castrol. So any Castrol oil will not be better than any sold by these 2 companies.
Old May 21, 2006 | 09:00 PM
rellik's Avatar
mercedes
i run 0W-40 Mobil One synthetic
Old May 22, 2006 | 01:53 AM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
Don't waste money on synthetic oil......they full of crap.........
Old May 22, 2006 | 01:57 AM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Mobil 1 0W-40 is your best bet for gas, and Mobil 1 Delvac 5W-40 for diesel.. But if it's an older motor.. (pre-Mobil 1 era) then Amsoil or other finer quality synthetics will do.. but DON'T use Castrol or other quasi-synth oil.. it's crap.
Old May 22, 2006 | 02:02 AM
SL BRABUS's Avatar
I try 0W-40......and I don't get better MPG..........That way I think synth oil is full of crap.......
Old May 22, 2006 | 08:10 AM
HLG600's Avatar
2009 SL63 AMG
Yeah that's what I've been hearing lately. I was recommended GTX at 3000 mile oil change intervals. How often do you change oil?
Old May 22, 2006 | 11:22 AM
cap'n jasper's Avatar
W124
There's more to synthetic oil than better fuel consumption.
It doesn't break down so easily when hot for a start.
How much cheaper is dino oil? How much is your engine worth?
Old May 22, 2006 | 11:51 PM
SL BRABUS's Avatar
I change my oil every 5000 mile or every year which ever come first......I use mobil clean 5000...... GTX are fine too...... don't worry about it.......you could change your oil between 3000 to 5000.......
Old May 22, 2006 | 11:57 PM
SL BRABUS's Avatar
I don't want to do so much explaining about the synthetic oil......here in US we have a class-action lawsuit....... people vs MB.....about synthetic oil..... do some search on the website and it will tell you the whole story......
Old May 27, 2006 | 04:29 AM
agentMurdoc's Avatar
Just changed my oil, was using Mobil 1 10w30. After 5200 miles, the oil was still a healthy shade of brown. Not incredibly dark like I was expecting. Wanted to continue using the same oil, but the filter was really dirty and I figured if the filter gets changed, might as well change the oil with it.
Old May 27, 2006 | 04:20 PM
ChrisB's Avatar
1999 SL 500 & 2011 E 550 4Matic
With the Flexible Service System the A and B services (5 so far in the 80,000 miles) have run about 9,000 miles apart.
That is when the synthetic oil and filters are changed by MB on my car.
I have not seen any other requirement for oil changing.
I'd say I drive very hard at times. I like those 0 to 100 mph flat out acceleration runs from time to time. I regularily employ the highway kick down passing acceleration. I have been known to drive at high speeds when out in the boonies.
Two years ago and again this spring the motor consumed at least a quart of oil in about 5,000 miles each time. Causing the low oil light to come on and require a quart top up.
Is this normal?
